Got the latest flash yesterday!
First let me say hats off to the site and forum. I have learned a lot in the last few months.
I took my 08 F-250 SD Job #3 into the dealership yesterday and had the latest flash done. I am thoroughly amazed and pleased with it so far.
I noticed some immediate changes in the shifting and power, not to mention in the fuel mileage.
At 55 MPH I was and am still running around 1450 RPM's and at 65 MPH it was running around 1750 RPM's and also made no change in the RPM's. HOWEVER fuel consumption appears to have decreased significantly.
I live almost two hours away from the dealership and frequent that trip and the town often. It used to take me 1/4 tank of fuel to make the trip. After the flash yesterday, it took just a little bit over 1/8 tank to come home yesterday.
There has been a lot of talk, questions and answers concerning mileage posted hear lately, and I know it has a lot to do with driving habits and I also know that the in dash computer is only and average. With that being said, I also noted yesterday and today driving the truck after the flash that driving at 55 MPH I used to get 14.5 to 16.5 MPG and at about 73 MPH on the interstate I was lucky if I could get 16 MPG. Since the flash yesterday and driving including my comute to and from work today I was pleased when the puter told me 18 to 19.5 MPG at around 60 and still got 17.5 on the interstate.
I see several post with people still having problems with their trucks and telling of bad experiences with dealerships.
Technology has come a long way over the years, and the smaller dealerships are doing everything they can to stay in buisness and I hate to say it, but many of them do not put enough emphasis on training for their techs. My advise to you that are having problems, find a dealership that trains their people and you wont have these problems. The days of guessing and shade treeing are over. My dealership and it's service manager are top notch and are very, very knowledgble of the new emmisions. The service manager took the time to explain everything to me, and even took me back in the bay area and I observed the flash being done. The tech told me what to expect as far as what the flash would do and he was right on the mark. He also explained that the fuel consumption would drop because of the change in the shifitng paramiters and the torque converter not being locked up so much as before. Heck they even gave me a free wash and oil change while I was there. How is that for service?
I am curious to see how it handles the regen now, and hopefully it will not be as bad on fuel consumption as before.
To those who may be procrastinating over the latest flash, I say do it, but let someone who knows how do it.
Good Luck!
Good Luck!
I just had My 08 350 done. I brought my truck in for an oil change and I got it back with the flash and no explaination. MPG is up, but performance is down. Also it goes into REGEN way more than it did before. I thought I was making about 35 Psi of boost before but now all it will make is 26. The truck has less than 5000 miles now and about 1000 on the new flash.
Flash version
Is there a way to push a sequence of buttons on the dash to get the computer to show the flash version(s)?
My dealer did the 8B07?? flash two days after it was announced but I believe they did not load the correct version. My truck does not show "cleaning exhuast filter" except for a split second then goes away.
thanks
thanks
thanks
thanks
I had the reflash done on my F350 4x4 dually on Monday. I took the truck on a short 60 mile interstate trip at 65 mph to compare with a trip I took before taking it in. I always reset the fuel mileage avg. when I first get on the interstate and make a round trip and check the mileage when I get back to my starting point. The mileage was 14.5 on both trips. So that looks the same but the boost was higher. On flat ground it was 9 to 10 and any incline it was 15 to 18 and when I pushed it it seams to max out at 26 to 27 lbs.
I just got my Job-3 truck back this morning. I haven't noticed any difference in the 30 or so miles from the dealer. Maybe I just need a little more time and experience with the new flash. They also re-did the venturi update after I did it. I guess they didn't trust me with that delicate operation.
I had the 08B07 update done, and I have mixed emotions about it. The IC now displays when I'm in regen mode, but regen seems to be back to the way it was 2 flashes ago. I _really_ liked the way regen worked on my last version, but unfortunately the IC would never tell me unless I went through the whole system check manually. I could barely tell when I was in regen mode before.
NOW with this update, regen is brutal. I was taking off from a light earlier today, and I made it across the intersection on a slight uphill, and then it seemed like the engine cut all power for 3 seconds then went back to normal.. During the 3 second 'lag' the engine was making the old racket it used to make when in regen mode on my original version of code. After the lag went away for 2-3 seconds, it came right back for another 3-5 seconds. During this time pushing harder on the go pedal seemed to have no impact in my ability to continue accelerating. Mind you I'm still going under 15mph. It also seems that my regens have locked me into 20psi of boost again.
I feel like I took a big step back in time.
Damnit ford, give me the last PCM code back, with the IC upgrade.
I guess I'll wait through another regen cycle and see what happens. I had big power problems when towing with my early code versions. Only my last version fixed it. I only upgraded because Ford put the disclaimer on their 08B07 notice that said if something breaks it's my fault for not updating.
First - the problems you mention under 15 mph shouldnt have anything to do with a regen. If you are in regen under 30 mph then your software/flash is not working properly and needs to be reinstalled.
2nd - if you cant get over 20 psi boost then it sounds like you are either in limp mode (built in safety on the truck) or you have something like an intake tube or CAC loose.
I would take it back to the dealer to have them assess it.
I have had the 08B07 flash for 3 months. My truck does not have to remain at 30 mph for regen to be in process. It may have to be there to start, but if I stop for a light or stop sign it does not quit. It only quits when complete or when I shift the transmission to N or P. As long my transmission remains in Drive, at least on these short stops, it does not cancel a regen that's in progress.
Correct Larry. Regen stops when shifting into P
