2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Frozen Driver and passender windows
Old 01-05-2009, 09:04 AM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
Hey Folks,
I was wondering if anyone was having a similar issue with frozen driver and passenger side windows due to frigid temps even after a 20 minute warmup with the heat on. I can hear the motor trying to open the window but it just doesn't
It's happened 3 times in the past month.
They eventually free up but its pain in the butt when you need to show your badge to base security.
Old 01-05-2009, 11:29 AM
gristanv's Avatar
gristanv
gristanv is offline
Cool
Yes, I have the same problem on my 2007 EB.
Old 01-05-2009, 11:50 AM
berry1234's Avatar
berry1234
berry1234 is offline
They probably used an inferior grease that hardens at low temps. Take it back.
Old 01-05-2009, 08:27 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
Is the glass freezing to weatherstripping or is the mechanism binding?
I'd bet it's the glass. Try spraying silicon on every edge of the weatherstripping that touches the glass and you'll probably be fine.
I used to wash cars (for $) outside all winter long. If I siloconed the weather stripping nothing ever froze shut.
Old 01-05-2009, 09:34 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Yup, lube the weatherstrip...
Saw this post earlier and gpfarrell beat me to the answer.
Lube the weatherstripping with silicone spray and they won't freeze shut. Might smear the glass a bit, but they'll open.
You'd have to fill the door full of water to freeze the regulator mechanism.
George
Old 01-06-2009, 10:31 AM
berry1234's Avatar
berry1234
Easy test. Pour some luke warm water on the window where it meets the seal. If it helps, its the seal, if not its the motor.
Old 01-07-2009, 08:58 AM
tirnaog's Avatar
tirnaog
tirnaog is offline
Aye this has happened to me too.
That silicone spray, can be found at local car stores?
Old 01-07-2009, 09:09 AM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Sure, it should be easy to find at any auto parts or hardware store...it's quite common and otherwise useful around the house.
In addition to the window weatherstripping, a bit on the door weatherstripping can help if your doors tend to stick shut when icy. For the door weatherstrip, I'll just spray some on a rag and do a wipe around the perimeter.
Another great use is to spray your snow shovel and the chute of your snowblower with it--that sticky wet snow won't stick as badly.
George
Old 01-14-2009, 06:36 PM
flyboy5111's Avatar
flyboy5111
flyboy5111 is offline
Mine does the same. The motors seem weak. My 04 F150 never did this.
Old 01-23-2009, 02:48 PM
Bopper's Avatar
Bopper
Bopper is offline
Mine is 2 days old and they seem weak. Yes, it has been cold though.
robrobinette
1999 to 2016 Super Duty
01-15-2012 08:29 AM
jasonodsky
12-11-2010 08:27 AM
Lobo
1997-2006 Expedition & Navigator
02-15-2010 11:41 AM
57f100man
05-25-2008 11:04 PM
seebee
02-22-2007 09:20 PM
Quick Reply: Frozen Driver and passender windows
