Tired of the 300 bashing - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 01-22-2009, 09:53 PM
nevrenufhp's Avatar
nevrenufhp
nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
YouTube - Ford 300, cam
This has the Cliffy valve cover. It took well over 3 months to get it, after it was ordered. Going thru comments, I got a lot of 300 bashing, but about 90% was positive. I took the video, it's my nephew's rig.
  #62
Old 01-22-2009, 10:01 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
Nevrenufhp--
Nice valve cover--and nice engine. Can I ask what type of exhaust you have on that rig?
  #63
Old 01-23-2009, 08:35 AM
nevrenufhp's Avatar
nevrenufhp
On my 67, it's a Hedman heddder(bad idea on a Bumpside). and 2" to 2 turbo muffs, then dumps under the truck.
The 72 in the video has the same heddder, but 2.25" pipes with 2 Flowmaster 50's. No crossover pipe or anything. It does beat V8s too.
  #64
Old 01-23-2009, 10:08 AM
Freaksh0w's Avatar
Freaksh0w
Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
One time I saw a Honda beat a V8. A 305 TBI fbody from the 80's... and your point is
  #65
Old 01-23-2009, 07:47 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
Originally Posted by F-250 restorer View Post
I forgot to mention the Clifford 6=8 polished aluminum valve cover, which, of course, instantly boosts the hp by 20!! at least.
Don't answer freaksh0ws question or anything. It's not like he was not the only one who wanted to know.
  #66
Old 01-23-2009, 10:45 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
one day when i have time money and space i want to build a carbed 300 just for kicks cause that valve cover dont work for efis lol
  #67
Old 01-24-2009, 06:25 AM
6CylBill's Avatar
6CylBill
6CylBill is offline
Hey, you work for a big rig company, right? I just learned how relatively small the motors are in these big rigs. I couldn't believe it! The motor in the Kenworth my dad drives is only 375 CI's. I'd like to know the bore and stroke stats.
Jacking done.
  #68
Old 01-24-2009, 07:00 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Jacking done.
Most semi trucks state the size of their engine by horsepower, not ci's. And they typically use liters today too when stating the displacement. Is it a caterpillar, cummins, or detroit engine? Most of the engines in todays semi's run between 12 and 16 liters.
  #69
Old 01-24-2009, 05:47 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
No, he meant CI's, I believe. It's a Cat straight six. It has 500 horsepower twin turbo.
The gear ratio's are similer to trucks, too. Obviously the ring and pinion are the same, but the final drive is still referred to "3.83" or whatever. I thought that was interesting, too.
http://www.youtube.com/watch?v=jMisS...e=channel_page
  #70
Old 01-24-2009, 09:07 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
YouTube - Pop's Rig
that engine could either be a c13 (13.6L) or a c15 (15.8L) i THINK i cant remember exactly yes gear reatios are pretty much the same its the tranny ratios that are different take 18 gears vs. 5...yeah they got 4 or 5 granny gears lol and the main granny gear is incredibly low and technically there is only 9 foreward gears but you can split each of them in half to get the 18 that way there is less of a gap between the gears....that 500 hp. engine also puts out roughly 1600-1800lbs of torque
my dads 2001 peterbilt 379 has a cat c15 single turbo pushing 625 hp. dont know how much torque hes got but its in the range of 1800 im thinkin never heard of dyno on a semi lol
hehe yeah sorry bout the
if i remember monday i will try to confirm the #S for ya
  #71
Old 01-24-2009, 09:21 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
actually theres some cool vids on youtube of truck drags out at a truckfest in quebec theres these 2 trucks out there that work daily but are totally built...i think they are both c15 cats but one pushes 2000hp and the other is 2400hp watch these 2 trucks drag...with over 100000lbs of weight behind them watch the frames twist and the front wheels come off the ground its sick
this tan and red peterbilt driven and owned by nicholas gagnon (the one on the left) is the one with 2000hp
YouTube - Nicolas Gagnon Rodéo du camion 2007
this is the 2400hp. western star driven and owned by eric bouchard
YouTube - Eric bouchard show de boucane camdrag matane
this is what you get when you put em together
YouTube - Éric Bouchard vs Nocolas Gagnon
remember each of these truck is loaded with well over 100000lbs
  #72
Old 01-25-2009, 09:02 AM
Econoline 150's Avatar
Econoline 150
Econoline 150 is offline
Econoline 150 is starting off with a positive reputation.
Yes that's true, Cummins 250,290,335,350,400 were all the same 855 cid size, just different setups for power. Them old Detroits (53,71,92s) were listed by cid per cylinder and were avabile in 2,3,4,6,8,12 and 16 cylinder setups depending on model. The Cats werent listed in displacement they listed the model like the 3208 was a 600 something cid V8
  #73
Old 01-25-2009, 09:06 AM
Econoline 150
Yes that's true, Cummins 250,290,335,350,400 were all the same 855 cid size, just different setups for power. The only ones who still call their cid size I can think of off hand is International, the Dt466, 570, the 365 (the 6.0 in Ford trucks) Im late to his thread, but Im happy with my old 300, its not perfect, but its faithful and Im comfortable with them as a pair of old shoes.
  #74
Old 01-25-2009, 08:18 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Hey thanks for the info! I think you guys must be right. Suren't it's not a 375 CID I6. I've seen it and it looks mammoth. It has to be more like 800 CID.I forgot about the 18 speeds, too. That helps get the load going down the road too.
  #75
Old 01-25-2009, 09:11 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
yep...the ole 3408 is one hell of a v8...the guys with the 460s think they got motor and the 3406 is an inline 6 but it became the c15/c13 sometime between 1998 and 2000
yeah im not sure on the cids of these engines as i have actually never seen one in person with a cid listed on it...that ive noticed and yeah theres no way its 375cids at least 600 maybe a little c7 cat or something...i was thinking one of those in a pickup but they are too heavy
Quick Reply: Tired of the 300 bashing
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
