Tired of the 300 bashing - Page 13 - Ford Truck Enthusiasts Forums
  #181
Old 02-04-2009, 03:06 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
They are throwaway motors as well. On the farm that I work at for harvest there are 4 or 5 old Fords with the 3208s in them. They are all N/A and are absolutely gutless. I finally got into one of the Internationals this year and from now on with a cummins in it and they are rocketships compared to those old Fords.
  #182
Old 02-04-2009, 05:00 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
True. In the IH I have always loved the DT-466's
  #183
Old 02-04-2009, 05:35 PM
ElwoodMurphy
ElwoodMurphy is offline
ElwoodMurphy is gaining momentum as a positive member of FTE.
Originally Posted by 6CylBill View Post
Hello my friend!
What is your FlareSide geared? Your manny helps in the fuel department also.
Like I said 300's are thirsty critters. They make more power per cylnder than any other small V8 out there. These are big six's and require a lot of fuel, every bit as much as a 302.
Now again, I'm not saying a 300 can not get good fuel mileage. Of course one man's idea of "good" is another man's "unacceptable". My idea of good fuel mileage for a 300 is 18. I've heard accounts of 20, even 21.
By the way Doug, I get about 15 highway also. I can't confirm this but I'm fairly sure it's about 15.5 and about 8 or 9 around town.
I find it amazing you got 20 mpg out of a 318. Those things are realiable but love their fuel.
Mine has the 3.55's in it with 31" BFG's. The 318 I had was in a 66 Fury with a 1 barrel carb.
  #184
Old 02-04-2009, 08:08 PM
Econoline 150's Avatar
Econoline 150
Econoline 150 is offline
Econoline 150 is starting off with a positive reputation.
Yes they are, no sleeves, the 8.2 Detroits and triple nickel Cummins were also trow away engines in my opinion.
  #185
Old 02-04-2009, 08:20 PM
1979 Ford's Avatar
1979 Ford
Drove a truck with the 8.2 for a while. I really wasn't impressed with the fuel pincher.
  #186
Old 02-04-2009, 08:31 PM
Econoline 150
They were good on fuel, but thats about it. The DT466 is in my opinion is the best medium duty engine out there.
  #187
Old 02-05-2009, 11:18 PM
FARM69's Avatar
FARM69
FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
People put too much credit in the 300's lifespan. It doesn't live that mucch longer than any other V8. I've heard of 200K+ 302's, 300k+ 318's, 200K+ 305s.. A lot of it depends on how the motor was used, and maintainted. What does make the 300 special in this case is how stubborn it is. After 200K+ miles, your 300 is still going to work very hard for you. Really if you think about it, the 300 should live longer than it does, having an inline configuration and two less cylnders, plus it doesn't rev high at all. If you reach 4,000 rpm you're pushing it too hard.
Tis a good motor.
Of course it should live longer. It has less moving parts than the 8 hole does. I've owned a 302 of the same year as my 300 and it went through when engine at 99k and the guides were leaking a 130k.
My 300 is no gem anymore. The stock clutch is about toast and the ball joints have probably rusted away. Highway travel is a struggle unless you keep the rpms up as the compression can't be too high anymore. Its a perfect truck for running back in fourth into town.
3208 CATs? Put those in the boneyards.... They might have been decent in their time, but that was years ago. Today's engines are a heck of a lot more efficient than those old gals.
  #188
Old 02-05-2009, 11:33 PM
1979 Ford's Avatar
1979 Ford
I like the 466. I spent some time in a tandem dump with the 466. I was moving a bigger load with the 466.
  #189
Old 02-06-2009, 12:42 PM
Freaksh0w's Avatar
Freaksh0w
Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Is that the truth? Your 302 was what? at 99k miles? You had to rebuild it? And then it was worn out 30k miles later?
Either way, both are ludicrous. My 302 has 122k miles of work on it, and it doesn't smoke at all, uses little to no oil, and runs like a champ. Guess it just depends on how well you take care of an engine. Being that I work my truck, I change the oil every 3k miles, sometimes less if I feel like I've been too hard on it, lol.
  #190
Old 02-06-2009, 01:29 PM
Econoline 150
FARM69, the 3208s , my employer had a new fleet of Chevrolet C70 Kodiaks they bought new in late '79. They were blowing up so often we kept several crate 3208s aside to reduce downtime.
We really went through some lousy diesels in that era; the best ones we had in our in the fleet were mid 70s International Loadstars with Detroit 6V-53s.
Most 302s I've come across were rugged little V8s and long lived. Not my first choice for a pickup engine (no offense to anyone), though, better suited in a Mustang in my opinion.
  #191
Old 02-06-2009, 05:10 PM
FARM69's Avatar
FARM69
FARM69 is offline
Those old 2 stroke Cat killers were a pretty good engine as well.
Anyways, my trucks are treated better than most as far as R/M goes. The 302 experienced more work and was used more for farm work and hauling than the 300. I sold it a few years back and it still ran decent with 40k on the reman. One of the valve guides was letting some oil by on the right side making it smoke a little at startup but it wasn't anything too concerning.
Like anything, you are going to have variables. They are all good engines. As far as the moving parts, it's sure cheaper to maintain a 6er (unless its a dang CAT)...
We've switched over to diesels for our farm trucks, but I'll stick up for a 300 anyday.
  #192
Old 02-06-2009, 07:57 PM
Freaksh0w's Avatar
Freaksh0w
Yeah, I'm not saying it's the best truck engine, just that they shouldn't give out at 99k miles. Something odd happened there. My truck has hauled wood, cattle, vehicles, you name it, all its life. And it runs like a top. Not to mention, I take it to 5000 RPM everytime I drive it. I can't help it, it just keeps pulling so good, lol.
  #193
Old 02-07-2009, 12:15 AM
6CylBill's Avatar
6CylBill
6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
I'm always amazed at what a V-Gasser can rev to. My mom's 3.0 revved to 6,000 today getting on the highway. I was amazed. The highest rpm my 300 ever sees is 4,000 - I'm abusing it at that point.
How high can a 302 rev safely?
  #194
Old 02-07-2009, 10:36 AM
Freaksh0w's Avatar
Freaksh0w
I've had mine to 5200-5300RPM, but it really slows down about when I get to 5000RPM. One time I burned out on the hill above my house, and my gas pedal got stuck down, and I don't know what RPM it was bouncing off of. I guess it has a rev limiter, if not... I dunno what was going on, it took me about 2 - 3 seconds to cut my truck off. I was stomping on the gas pedal trying to make it come back up, lol. Problem was under my hood, needless to say, I fixed that problem. That was about a year ago, thank god it didn't blow anything up. It feels like abuse if I go passed 5000RPM, but I don't know the actual RPM where things start to do damage. I think the 5.0's in the Mustangs come with a 6000RPM redline, don't they?
  #195
Old 02-07-2009, 01:26 PM
rikard's Avatar
rikard
rikard is offline
rikard is gaining momentum as a positive member of FTE.
I"ve had both a 302 and 300 in F150s. I liked the six for the low end power and the 302 for the ability to rev. The six is easier to work on and is a true truck engine. My 302 made it to 220k miles with 20k hauling a 5000lb RV trailer. Both of my 300s have used less oil and have have been rock solid. If my 300 ever goes out I would consider the 302 but not with the 3.08 gears
As far as diesels go the absolute worst was the old Toro Flow GMCs followed by the Olds 350 diesel.
I have always liked the 466/530 and the DT360/408 "cornbinders"
regards
rikard
Quick Reply: Tired of the 300 bashing
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
