Tired of the 300 bashing - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 02-02-2009, 09:31 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Originally Posted by 1982bluef150 View Post
i quit 12345
Why? Perhaps because it is going to take a hell of a lot more than what you posted to even knock on the door of 30mpg let alone 50?
  #152
Old 02-02-2009, 11:00 AM
1982bluef150
1982bluef150 is offline
1982bluef150 is new and has a neutral reputation at this point.
nah its because all you do is jam your head in the sand i bet you wouldnt beleive that my car that gets damn close to 40mpg highway STOCK would probably stand right next to your big bad 5.0
and its 3 years OLDER
  #153
Old 02-02-2009, 11:34 AM
MisterCMK's Avatar
MisterCMK
Avid Winter Hater
And what car is that?
  #154
Old 02-02-2009, 12:36 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
Because even POS prius gets maybe 35 MPG. No we are not sticking our head in the sand. Most of us around here have been around, and can detect BS pretty easy. Most gadgets that are on the market have been tested and guess what... They have failed miserably.
The MDS on the Dodges doesn't even realize 30 MPG and the Cadillac had a 8-6-4 engine that failed as well. So if the technology was there I would bet they would be featured as OEM on most modern automobiles.
So who has their head in the sand?
  #155
Old 02-02-2009, 12:41 PM
1979 Ford's Avatar
1979 Ford
40 MPG? What is it a Geo Metro?
Ford Focus is only good for 35 MPG. The only vehicle from the factory that offers 50MPG in North America is the VW diesel.
  #156
Old 02-02-2009, 07:32 PM
waynaferd's Avatar
waynaferd
waynaferd is offline
waynaferd is starting off with a positive reputation.
Mmmm....and you can get all the bigger turbos, reprogrammers, etc you can for a truck for them v-dubbs, too.
The owner of a diesel performance shop around here has a TD Jetta, with big clouds of black smoke and all, and that little f--ker is nasty. Fast is a considerable understatement
And I want one.
  #157
Old 02-02-2009, 08:27 PM
1979 Ford's Avatar
1979 Ford
And I want one.
I would love to have a TD Jetta. But diesels are grossly underused in North America.
  #158
Old 02-02-2009, 10:22 PM
1982bluef150
id love to see a geo metro fry the tires off through 2nd gear once i was just driving around cuz i was bored and i hopped off the highway and was sitting in line at a light and locked the brakes up and just left my clutch out didnt tach and du,p it or anything just acted like i usually do when i pull out... i almost flipped because i thought the clutch was slipping.... then i saw the smoke so it was fine
and on the van... the guy did admit to it dropping to 30mpg when it wasnt completely empty and did you ever stop to think that maybe they did all these tests on a dyno so then wind resistance wouldnt be a factor?
and this isnt a miracle effing plug in toy.... i never said that all i ever said was this thing was HEAVILY MODIFIED
and ill never tell you what kind of car i have ill tell you if youre right when you guess tho and im not completley positive id stand next to a 5.0... nobody ever wants to play no more... well they did but that was only when my car was slow cuz i de tuned it on purpose to break my clutch in...but i did find a 4.6 stang and we played around a little and when it was all over dude gave me a big thumbs up so thats sayin something specailly considering my car is slower than stock because im not even running the correct computer and the more i think about it the more i think that cars a freakin rocket ship considering i slapped a motor from an 85 in there
  #159
Old 02-02-2009, 10:32 PM
1982bluef150
Production 2000–2003
Assembly Toyota City (Motomachi), Japan[8]
Class Compact car
Body style(s) 4-door sedan
Engine(s) Toyota Hybrid System
Gasoline: 1.5 L DOHC I4 VVT-i
13.0:1 compression
52 kW (70 hp) @ 4500 rpm
110 N·m (82 lb·ft) @ 4200 rpm
Electric: 273.6 V motor
33 kW (44 hp) @ 1040 rpm
350 N·m (258 lb·ft) @ 0 rpm
SULEV
Transmission(s) 1-speed planetary gear
Wheelbase 2,550 mm (100.4 in)
Length 4,308 mm (169.6 in)
Width 1,694 mm (66.7 in)
Height 1,463 mm (57.6 in)
Curb weight 1,254.2 kg (2,765 lb)
oooo woweeeee the light version of the prius still outweighs my car by like 15 pounds and before you start crying that i cant weigh my car with my bathroom scale because it wont be accurate i had it weighed at the scrap yard that pays me more than i expected to get every time (i try to keep track of the weight of all the stuff in the truck to see if i get screwed by a huge amount) and obviously their scale is accurate or else they are losing money
  #160
Old 02-02-2009, 10:48 PM
1979 Ford's Avatar
1979 Ford
Class Compact car
13.0:1 compression
SULEV
No one is buying your story.
Methinks we should quit feeding this troll.
  #161
Old 02-02-2009, 10:59 PM
1982bluef150
i dont care... been there done that you cant tell me what i saw just like i cant make you beleive me...
and i did quit already the dillhole up there with the gay mustang wouldnt let me
  #162
Old 02-02-2009, 11:01 PM
optikal illushun's Avatar
optikal illushun
optikal illushun is offline
optikal illushun is gaining momentum as a positive member of FTE.
man, way to be a real man about things, callin someone a dillhole with a gay mustang.
  #163
Old 02-02-2009, 11:02 PM
1979 Ford's Avatar
1979 Ford
you have not offered any proof. When the BS card was thrown out you could not answer. People here have called your bluff.
Until you offer some legitimate evidence, your statements are BS. Pure BS.
  #164
1982bluef150
oh yea and a turbocharger does wonders for fuel economy and power
also its not dudes fault his mustang is gay... i just dont like how 90s cars got all smooted and blended... now weve had this vert mustang in where i work for like 6 months now and that thing has made me almost go shopping for one.... its in the fox body era
gloss black with a black top cobra wheels and totally gay ricer tail lights that ruins the whole freakin thing... but hey to each unto their own right?
  #165
Old 02-02-2009, 11:03 PM
1982bluef150
ok give me a list ill see what i can do
Quick Reply: Tired of the 300 bashing
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
