fuel relay--how to get power to?
Old 04-05-2010, 10:24 AM
pro70golfer14's Avatar
pro70golfer14
pro70golfer14 is offline
We did a carb swap to my buddys ranger and now we can't get the fuel pump to come on. To get it on i guess we are going to power the fuel relay. Where is it and will this work.
Old 04-05-2010, 10:00 PM
wtroger's Avatar
wtroger
wtroger is online now
If you put a carb on a ranger that was fuel injected you don't want to run the electric fuel pump carbs are made to handle about 5 -7 lbs of fuel pressure the electric will make between 40-60 psi. The needle and seat on a carb won't hold that kinda of pressure. you will have to go with either a mechanical pump or a low pressure electric or you might be able to find a regulator for the factory pump.
Old 04-06-2010, 09:11 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Besides, why on earth would you want to swap to a carb? All the components for fuel injection are present and the automakers went to fuel injection for a reason.
jumbofordman
02-02-2015 05:15 PM
suprdzlduty
03-09-2008 12:20 PM
jasonmoss
12-21-2004 08:13 PM
FireMarshal3311
08-31-2004 08:31 AM
Riptor22
Electrical Systems/Wiring
05-03-2004 09:48 AM
Quick Reply: fuel relay--how to get power to?
