British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
auxiliary idle control
Old 01-12-2009, 09:06 PM
madone04's Avatar
madone04
madone04 is offline
Cool auxiliary idle control
Hello I am looking for info on the auxiliary idle control system,
I just purchased one and it did not come with a wiring harness, my local dealer says i have to purchase the whole unit from the to get the harness, but I don't want to spend $1300 bucks one just for the harness, so I am wondering if anyone knows where I might find one,or if someone can give me a layout of the harness so I can build one, mine is full function for an 03 f350 6.0 psd
Thanks in advance for any info that may be available.
Mike
Old 01-12-2009, 10:11 PM
Vinford's Avatar
Vinford
Vinford is offline
I see them on Ebay sometimes.
Maybe you can buy the whole thing with harness cheap?
I had a guy give me one but I gave it away.
Old 01-12-2009, 10:47 PM
madone04's Avatar
madone04
madone04 is offline
That's where I bought this unit... didn't realise that there was no wiring with it
Old 02-01-2009, 01:17 AM
Flatdeck's Avatar
Flatdeck
Flatdeck is offline
It'll probably be cheaper for you to buy another one with a harness... I bought 2 from eBay, for $35 and $40 each, incl harnesses. They didn't come with the brackets, but a buddy is an aluminum fabricator so he's going to build me a custom console for the AIC and a VHF radio.
Old 02-01-2009, 09:49 PM
FlyCanadianGuy's Avatar
FlyCanadianGuy
FlyCanadianGuy is offline
Mike
My work truck has it installed, i'll follow the wiring on Tuesday when im in the shop and let you know. I believe (but could be wrong) that it is simply run straight to the PTO wire under the dash and the resistance in the switch you have determines your RPMs. I will check it out Tuesday, be patient. BTW, how much was your switch?
