2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Brakes?
Old 01-09-2009, 01:56 PM
carbonmetallic's Avatar
carbonmetallic
carbonmetallic is offline
Brakes?
I have roughly 30K on my 07 expedition and my brakes are screaming everytime I go to slow down, whether it be at red lights or on the highway. Is it normal for the brakes needing to be replaced this early?
Old 01-09-2009, 02:50 PM
berry1234's Avatar
berry1234
berry1234 is offline
I don't know if it is 'normal' but Fords typically eat brakes. I don't think it is unusual for it being a heavy, 6,000 pound SUV.
Old 01-09-2009, 04:25 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Napa Ceramics: They are good but do not develop any more friction than good quality OEM linings
Performance Friction & Hawk: Good braking, increased friction but very dirty compared to OEM.
Recommendation: CarboTech Engineering lining, which I have used for about 15+ years and been very happy on multiple full size (V8) cars and trucks. This particular lining has a high friction co-efficient, excellent pedal feel, wear (typically 50,000 to 75,000 miles before replacement is required) and produces less dust than OEM linings. IIRR, I paid about $130 for my last set including shipping. They have a web site at Carbotech Performance Brakes, but I highly recommend speaking to them by phone for linings that would be best for your application at 877-899-5024 or 704-481-8500. With regards to rotors, I run Brembo OEM replacement rotors that are cryogenically treated making them almost as hard as stainless steel. For street use, slotted/drilled rotors are just “cheese-graters” for the brake pads IMHO, because unless you are involved in true racing conditions, the brake linings do not produce the gases which slotted/drilled rotors are designed to relive. In some cases, brake testing indicated reduce brake efficiency in street-based operations using slotted/drilled rotors when equal comparisons were made. The staff at carbo can speak to you as well regarding those options, but I am very satisfied with the performance & wear of these products.
wolfrace
09-24-2020 07:27 PM
1981Ranger
09-22-2013 06:56 AM
jleo
04-04-2010 01:29 PM
Quick Reply: Brakes?
