Overhauling my 85 F150
#61
#63
#66
#67
#68
#69
It should fit, but don't take my 100% word. I have a hitch and was going to install it - if I did install it, it would've have to have been done before the fuel tank was dropped in. I'm not doing a hitch no more since I dropped the rear 2" and my 295's stick out past my wheel arch lip and trailer weight would most likely lead to me shredding tires - instead of burning them
#71
I managed to start and nit pick at several small projects including running prebent stainless brake and fuel lines, rebuilt p/s pump, driveshaft measurements....
I also laid out the exhaust last weekend, this weekend I cut and welded it. I rank it pretty high on the accomplishment list, and managed to finish it in one shot unlike the smaller tasks
I would've preferred to route it after the wheels but the 38gal fuel tank would've had it sitting too low.
For the record, the exhaust is on center, its the engine/driveline offset to the pinion that is off.
Old v. New
No hangers yet until I see where my driveshaft safety loops end up, but the jackstands are shimming it up to the right height. I measured and re-measured numerous times and it finished up near perfectly square and true. I'm happy with the paint too. I can't wait to hear it !!
Old v. New
#72
#73
Thanks!, and correct - I was running 16 before axle, 19 after earlier. 38gal is enough with one.
Too excited when I posted earlier:
- Flowmaster U-fit 3'' kit, 50 Series SUV mufflers, 12'' rolled tips (to install once bed is on for right depth)
- Jegs X-pipe kit with cutout provisions
- Doug's Headers cutouts
