1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Dome Light/Door Trigger wires for Alarm
Old 01-08-2009, 06:39 PM
lcolson
lcolson is offline
lcolson is starting off with a positive reputation.
Can someone please tell me where to find the Dome light or door trigger wire so I can complete my alarm hookup? I prefer the Dome light wire if possible.
My alarm works with either + or - signals.
<OThanks,
LC
Old 01-08-2009, 06:42 PM
lcolson
lcolson is offline
Sorry, I forgot to post 2008 F-250 Super Crew
Old 01-09-2009, 02:35 AM
ReAX's Avatar
ReAX
ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the security diagram before any remote start installation.
12 VOLTS Blue/red Ignition switch harness +
IGNITION White/orange Ignition switch harness +
ACCESSORY Violet/Green Ignition switch harness +
ACCESSORY 2 Brown/yellow Ignition switch harness +
STARTER Blue/white Ignition switch harness +
KEY SENSE Blue/gray Ignition switch harness +
TACH SIGNAL Blue In driver's kickpanel (loose wire) AC
May also be found in harness left of steering column.
LOCK Blue/green In driver's kickpanel -
UNLOCK Yellow/purple In driver's kickpanel -
DOORPIN Blue In harness from under driver seat +
BRAKESWITCH Violet/white At brake switch +
May also be Yellow/green in driver's kickpanel.
PARKLIGHTS Violet/white In driver's kickpanel +
HAND BRAKE White/violet In driver's kickpanel -
HORN Yellow/red Steering column -
CLUTCH SWITCH Blue/orange In driver's kickpanel
I would test the door pin (blue) wire, it should be (-) with the doors closed and (+) with any door open.
Old 04-16-2019, 07:34 PM
Godgiven22
Godgiven22 is offline
Godgiven22 is starting off with a positive reputation.
I have a 05 F250 XLT crew cab with Amp steps. I donít want to buy a new controller and harness just to have leds on them when I open the doors. How can I wire up leds to only come on when the doors open?
John Rowe
15
11-21-2016 09:13 AM
Joe in Austin
78
11-21-2012 11:34 AM
lakerats
03-17-2011 02:40 PM
lakerats
Electrical Systems/Wiring
12-08-2010 08:00 AM
lakerats
18
10-16-2010 09:10 PM
Quick Reply: Dome Light/Door Trigger wires for Alarm
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
