exhaust manifold gasket????
My kid's 2002 F-150 with 5.4L Triton had an engine tick. He had it out the other day......accelerated and heard a huge pop. The truck lost power and now there sounds like a massive exhaust leak under the hood on the passenger side.
I'm thinking exhaust manifold. If so, is this too much for a backyard mechanic?
Take a look at this kit, it is expensive but will do the job. There are pictures and a video there too. Good luck!
http://www.timesert.com/html/triton_repair2.html
It's difficlut , but not to the point of pulling the head. The trick is to use a good 3/8" air ratchet for your drilling. Also get short socket extensions to use. Take your time and be patient. It's probably going to take between 2-3 hrs to do it if you haven't done this one before. Triple check that you have the cylinder blown out good. I use a bore scope , but if your good you can use a flashlight and a mirror to look down the sparkplug hole.
Good luck!! You can do it!
