Suspension Confussion
Old Jan 10, 2009 | 10:57 AM
  #46
Pickupmanx2's Avatar
Pickupmanx2
Originally Posted by teds74ford
From the junkyard, you will need coil buckets, bottom cups and retainers, radius arms and caps, and the track bar and mount. The best bet would be to drive to the junkyard, look at what a fairly complete F150 has, and what you don't have.
Yup, physically looking at it is the best way right now, to start with, I would just get the whole front-end, radius arms and all, Coil buckets etc.
You should be fine with stock @ 4" lift, any higher, you need to start changing radius-arms, driveshafts, brake lines and so on.
Old Jan 10, 2009 | 04:27 PM
  #47
cowboyup11's Avatar
cowboyup11
I have a frame from a 90 something 4x4 it has the coil buckets and shock mounts and radius arms The coil buckets have 1 bolt and then round revites to the frame. if I cut the revites that go to the frame and replace it with bolts could I put this on my truck? It also has the bottom cups.
Old Jan 10, 2009 | 06:36 PM
  #48
teds74ford's Avatar
teds74ford
No. 70s trucks
Old Feb 11, 2009 | 07:09 PM
  #49
cowboyup11's Avatar
cowboyup11
Ok I have finally found what i hope to be the parts for this truck. I just wanted to get some opinions and some facts on whether or not this will work. What I found is a 79 F-100 4x4 parts truck on craigslist I was planning on taking off the radius arms, coil buckets, coils, front sping lower seat,front spring lower mount radius arm caps, axle insulator, front spring upper mount, radius arm bushings with torque lock nut, and the draglink. What I am wondering is if these will be a direct swap. Here is the listing for any further questions.
1979 F100 (parting out)
Old Feb 11, 2009 | 07:45 PM
  #50
cipsmithers's Avatar
cipsmithers
[quote=cowboyup11;7129727]What I found is a 79 F-100 4x4quote]
Someone correct me, but wasn't the last year for 4X4 f100's 75 or 76?
Old Feb 11, 2009 | 07:50 PM
  #51
cowboyup11's Avatar
cowboyup11
That is what I thought to but figured I would just put what the listing said in case I was wrong. but anyhow do you know if it will swap?
Old Feb 11, 2009 | 09:37 PM
  #52
cipsmithers
Those hubs look like 2wd hubs on the top pic. If it is 2wd, Im not sure how many parts will swap over to yer 4wd
Old Feb 12, 2009 | 10:04 AM
  #53
Pickupmanx2
Yep, from what I can tell that looks like a 2wd,,,, and 900 bones?!! 1979 FORD F-150 4X4
How much are you wanting to spend,,,, this has been on CL for a while,,,, maybe you could talk him down some and drive it home,,,
Old Nov 26, 2009 | 07:59 AM
  #54
bigblu78's Avatar
bigblu78
Sorry to stir up an old thread but I was wondering how progress was going on this... seemed to just die out. BTW I have a 79 150 parts truck with all the stock suspension if needed.
onebadpony00
1983 - 2012 Ranger & B-Series
May 2, 2022 11:46 PM
SpiritOf1976
New Member Introductions
20
Jun 27, 2018 09:50 AM
SpiritOf1976
34
Jun 26, 2018 01:40 PM
82fordowner
Oct 26, 2015 08:26 PM
61FordUni
Apr 22, 2015 07:53 AM
