I know that Mike (Big Poppa) didn't have clearance issues with his. Me on the other hand... I installed Diamond Eye duals and the clearances are... shall we say... tight.
I didn't have to cut anything that wasn't supposed to be cut in the first place, but boy getting that exhaust in there was a PITA. As I'm sure you read elsewhere, if I had to do it again I'd have spent the extra $ on the MBRP, plus it comes with tips which mine didn't.
Rick, the only issue i had with mine was how close the pipe AFTER the downpipe, it was so close to the trans cross member bolt, it rattled when idling. I had to undo all the clamps and downpipe and re-adjust. Just make sure you tighten everything down from the downpipe then work your way back and adjust as needed. This is a very nice exhaust and now MBRP makes a cheater pipe(straight pipe) for the duals if you wish. PM me and i'll tell you where i got them for about 200.00 less. Here,s a pic for install reference.
