06 Super Duty Tanny Relearn
I think this is most of it - pulled from another forum.
Torqshift Shift Relearning Strategy
TorqShift Harsh/Slipping Engagements, Upshifts, and/or Downshifts:
If these symptoms are experienced after the batteries have been disconnected, then it is due to the transmission adaptive strategy being cleared from the computer. This may occur when the vehicle is delivered new from the factory as well.
1. Warm the engine and transmission to operating temperature with all accessories off.
2. Idle engine for one minute with engine warm and all accessories off.
3. Idle engine for one minute with A/C on.
Then:
4. While driving, perform three series of upshifts at light, medium and heavy throttle.
5. While stopped, perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement.
Perform these steps once in normal mode and once in tow/haul.
Torqushift Gears:
The 5R110W, or TorqShift, automatic transmission is a redesign of the E40D/4R100. Basically, the gear ratio for first gear was lowered from 2.71 : 1 to 3.09 : 1. To get second gear the overdrive clutch is engaged to give a ratio of 2.2 : 1. Third gear is now the same ratio as the old second gear, 1.54 : 1. The TorqShift is advertised as being a 5 speed automatic, when actually it has six forward speeds. On cold engine operation (below 0 degrees) the overdrive clutch is engaged in third gear for a ratio of 1.09 : 1. The transmission will shift directly to sixth from fourth and fifth is skipped. On a warm engine the shift pattern would be 1st, 2nd, 3rd, 5th (direct drive), 6th.
Then:
Torqushift Gears:
indyraven
05-19-2016 03:05 PM
