95 F150 stutters b/t 1100 & 1400 RPM
I promise I searched the term "stutter"...maybe I'm not searching the right term...
95 F150 4.9. Idles smooth but start applying the gas and it stutters between 1100 & 1400 rpm. Above 1400 or so it seems to smooth back out.
I recently had an EGR code (I believe), so I removed it, cleaned it, reinstalled and after a few drives the check engine light stopped coming on. While reading the EGR posts, Do I remember seeing that the stutter might be connected to the EGR issue? maybe not?
Thanks guys...ya'll have really helped me out on several issues!
Thanks for the relpys....keep'em coming
OK guys...thanks for hanging in there. I went out tonight to read the codes by the method you described, not sure if I got the codes right though...argh!
The first time I read them I think I got: 15 39 53 9 which doesn't make sense. Maybe the 1 means nothing and it is really 539 539. When I look that code up in the KOEO column it says the defrost is on or something...which it wasn't...weird. Then it went to the CM code which is 332 332 I'm pretty sure....which means EGR valve...argh again!
So I waited 15 seconds to run the test again but it didn't do the same sequence of blinks. Makes me think it won't give me those first set of codes again?? ANyways, I recorded the 2nd test (after waiting about 5 minutes) and this is what I got:
check engine
what do you think?? remember...what you see in the video is AFTER the first test. I wonder how long it will take before I can get those "first run" codes again?
check engine
How long ago was your EGR stuck? You might clear the codes and take her for a drive and retest.
332 looks good to me though. It could be that your EVP (EGR valve Position) sensor is not registering the EGR opening and it is causing the rough idle. I would check this out first since EGR valves are not cheap. You can test the EGR is opening with a vacuum pump and the engine at idle. Appling vacuum to the tube thats on it and the engine should stumble. You should hear it open as well.
EEC IV Self Test hookup
I think this site has one of the best diagrams for counting the flashes.
Goldenvoice
04-02-2015 11:48 AM
DylanParker
1997 - 2003 F150
10-01-2013 08:42 PM
Dmntxn77
03-05-2012 12:57 PM
virginiacreeper
06-11-2011 07:09 PM
