1978 - 1996 Big Bronco
Big Bronco FAQs
  #91
Old 02-24-2014, 09:47 PM
Edds's Avatar
Edds
Edds is offline
Originally Posted by broncorunk
I don't think I'm on the right thing I'm new at this I have a 95 bronco with a 351w in it I want to put long tube headers on it and I'm not sure if I can my truck has the air to manifold I'm not sure what I have to do to put the headers on it can any one help me
I might be a little late of a reply so idk if anyone told you this but I heard that long tube headers aren't so good since it would be boiling your oil if I recall? It was something with oil but I suggest you put in shorty headers.
  #92
Old 04-02-2014, 06:09 PM
Michiganjfrog's Avatar
Michiganjfrog
Michiganjfrog is offline
33 12.5 tires too big?
I have a 1995 paid 800 bucks for her 302 engine bored .030 over freshly rebuilt trans custom duel sidepipe exhaust is this why it struggels to stay at 70 mph?
  #93
Old 04-02-2014, 07:11 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Are you meaning, are the 33 x 12.5" tires the reason?
If so, that depends entirely on what gear ratio you have in your differentials. What is your ratio?
  #94
Old 04-03-2014, 11:05 AM
Michiganjfrog
33.12.5 tires
i dont know the gear ratio as far as i know its stock
  #95
Old 04-04-2014, 04:19 AM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Michiganjfrog, recommend you start a new thread. You will get more responses. Welcome to FTE and the Big Bronco Forum!
  #96
Old 02-11-2015, 01:00 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Moderators, can we create a sticky like the 80-86 bullnose section has, or delete posts on here and lock this thread? Or maybe a how-to section? Then post actual FAQs and answers? i.e. tell new members to use the search function, then start a new thread if they can't find the answer, and how to post pictures. Also talk about 460 and diesel swaps, 4 door broncos, SAS swaps, soft tops, how f150s and broncos are the same from the doors forward, and things that are different between trucks and broncos. We could also post links to build threads that have the answers to common problems. I have lots of information that I would be willing to write, and others could add to if you wanted to?
  #97
Old 02-11-2015, 01:45 PM
1985 Bronco
I'm going to start posting info, but it would be nice if we could move it to the first page.
Did the bronco ever come with a 460 or diesel?
NO, it never came from the factory with one, but it is a very common and popular swap.
The 460 was available in 2wd 73-78 trucks, and in 2wd and 4wd 83-96 trucks. Therefore it can be a direct swap. I don't know the exact info for 78-79 broncos, but will edit later if I find it. To put one in a 80-96 bronco, you will need the correct/aftermarket motor mounts, transmission, wiring harness, radiator, and cross member or an oil filter relocation kit. I haven't had a problem with my truck, but others have reported that their front suspension can sag from the weight of the 460.
Putting a diesel in a bronco: there are 4 popular swaps, 6.9 IDI, 7.3 IDI, 7.3 Power Stroke, and the Cummins. The first 3 were available in Ford trucks from the factory. They are just like the 460, and require the correct cross member, transmission, wiring harness, radiator, and core support. Bronco suspension will not hold up under the weight of a diesel, and require the axels and suspension to be swapped as well. Diesels will also fit in 78-79 broncos, and there are many build threads of IDIs and Cummins swaps in the 73-79 truck section.
460s and diesels were available in 4 door broncos however...
  #98
Old 02-11-2015, 02:04 PM
1985 Bronco
4 door broncos were made from 87-96. Production numbers are around 4000 total. They were not made by Ford, and were aftermarket conversions. Centurion, Magnum, and Metropolitan were the bigger companies. there were also a few limo companies that did conversions. Each company had different names for them. Centurion made the most, and also made the crew cab F150. There were 2 types, stretched broncos, and f350 crew cabs with a bronco rear added. The stretched broncos frames were cut and lengthened, and the F350 based ones had shortened frames. They were built to order, each one was different, and were available in half ton and one ton versions. They were available with rear heaters, and are known for having rusty roofs. There is a forum dedicated to them with more info here:
www.fourdoorbronco.com
  #99
Old 02-11-2015, 11:45 PM
greystreak92
This is a sticky. The web page in linked on the first page is the purpose for the sticky. Admittedly the website has not seen an update in quite some time but the purpose was to alleviate the volume of repeated/duplicate questions that this particular forum used to field on a DAILY basis at times. Modifications are not emphasized on the site simply because they are personal preferences and not facts about the Bronco. In short, the intent was never to create an end-all be-all listing of information about modifications, uses, and variants lest the forum not be necessary.
  #100
Old 04-24-2015, 08:06 PM
dsw835's Avatar
dsw835
dsw835 is offline
sooo, what about the 6.0 Powerstroke?? I have a 1992 Eddie Bauer Big Bronco and have always wanted to put a diesel in her, but as you say, they are much heavier than the gas, so major modifications are required. BTW thanks for the posts here, I am learning a lot!
  #101
Old 04-25-2015, 05:27 PM
greystreak92
DSW,
Try posting this in a new thread. The FAQ thread won't be checked for new questions.
  #102
Old 05-17-2015, 07:33 PM
DannyH57's Avatar
DannyH57
DannyH57 is offline
Great Forum !
I bought my 85 Bronco a couple of years ago and although I've been a Ford owner all my life this is my first Bronco. Really glad to find a place to get advice on fixing up a vehicle that I have always wanted. Just want to say thank you for the add and all the help !
  #103
Old 05-24-2015, 08:33 PM
dbennett90's Avatar
dbennett90
dbennett90 is offline
Whats going on guys! Currently have a 83 Bronco parts truck and an 80 Bronco mudder project. Recently pulled the trans/tcase and motor on the parts truck...getting ready to straight axle the 80! For now it will have a 76 302 from a Thunderbird, working on getting my hands on a 460
  #104
Old 07-13-2015, 02:01 PM
mash4077's Avatar
mash4077
mash4077 is offline
im doing a transmission swap on my 1992 bronco, 351 Windsor, electronic 4x4.
Had E40D putting a m5r2 in, the issue im having is the clutch hydraulics. i have a new master, new line, and new slave, seems to be very hard to bleed. but i have noticed that there were little things ive had to do to get things working such as, the pedal did not travel far enough to release the clutch cut some of the pedal assembly to allow more pedal travel worked for a small amount of time. i have also noticed that the slave cylinder that is "made" for this isn't big enough, after bleeding system only got a 1/4" of travel in the slave then realizing that that was the the end of the slaves travel. i then put in some spacers behind the slave separating it from the trans and in return it increased the travel of the slave cylinder. what could be wrong with this?
the bell housing to deep?
wrong slave? wrong trans?
have tried multiple bleeding procedures including bench bleeding both master and slave cylinders i am at a total loss i think i could still use more pedal travel but again im not sure, but it still doesn't make sense that i would have to have spacers inbetween the slave and the trans to get more travel
  #105
Old 07-18-2015, 09:45 PM
greystreak92
Post questions in a new thread NOT HERE! STICKIES are for the original post. You won't get responses here!
Quick Reply: Big Bronco FAQs
