Oil leak in the valley
I have a leak from the HPOP plug and I have changed the o-ring a couple times now. I am getting frustrated with it so I was wondering if anyone could tell me exactly how to go about changing it. I have heard that the threads have to be completely clean of oil before you can reinstall the plug. that seems nearly impossible. So how can I clean the threads and also would anyone recommend putting High Temp RTV silicon on the o-ring. or should I just leave it dry.
Sorry to jump in on your thread with my own problem but, I really need help.
What type of O-ring are you using? Here's a write up on how to fix the end plug leak https://www.ford-trucks.com/forums/6...fferently.html
Have you done the CCV mod? If not, check the orange boots (they'll be covered in sludge and won't look orange if you've never cleaned it) below the IC tubes that connect to the intake manifold. The passenger one seems to work it's way loose and can cause a mess, or little puddle of oil.
The good advice has already been given. Clean things up, then keep an eye on it. The boots are easy to check and can work loose, so I don't mind suggesting you tighten them down first. A loose boot also tends to create an oily gunk on the EBPV actuator rod, which is another possible source for a small leak, so make sure you wipe that thing off too. It's a real pain to reach or even see, but stand on the passenger side and peek down under the exhaust coming off the turbo. The EBPV is part of the turbo pedestal.
With a loose orange boot, mine looked like this
If you clean it up so it looks like this
You'll be able to tell if you've got oil leaking out around the shaft after you drive it with the engine cold (and cold outside temps).
406ford
1999 to 2016 Super Duty
13
12-02-2013 08:39 PM
snaponprofile
18
09-16-2011 05:57 PM
