Delaware Chapter Join Chapter, Leader: pbsdaddy
DE January Chat Thread All Welcome
Old 01-10-2009, 10:22 PM
drunkdave's Avatar
drunkdave
drunkdave is offline
I dont think its the right hitch because the PO ground notched the bumper so it will clear a reciver, but it seems like it in to far. On top of that it dosent look right in my opion.
  #1532
Old 01-10-2009, 10:23 PM
80351's Avatar
80351
80351 is offline
Originally Posted by drunkdave
Im not sure but if im going to need to take the hitch off, I think its the wrong one any way. And of course, the bolst for the skid plate have nuts that are one size and heads on the bolts that are an other.
I don't think on my big one I have a skid plate but on the BII I couldn't get the polts out of the back by the bumper so I just undid the frontones and kinda pulled it back as far as I could.
I wouldn't look forward to tasking that 32 gallon monster out of the big truck
23 gallon was enough
  #1533
Old 01-10-2009, 10:25 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Originally Posted by 80351
Actually its 4 times,
Cut it, Split it, Stack and burn
dont forget the loading and unloading it in the trucks to haul it home... back home my grandfather just goes out and cuts down the trees in his back yard.. but here we ummm... lack some trees lol (city life) so if we want wood we gotta buy it and haul it.. course we dont use our fireplace.. cuz all it does is sucks the heat outta the whole house... doesnt even get the room its in warm really...
  #1534
Old 01-10-2009, 10:26 PM
80351's Avatar
80351
80351 is offline
I'll tell you without even seeing it what he did and chances are it is the right one. When you get the kit people forget to put the shim packs in between the frame paltes and the frame. Did that kinda work for a few years
  #1535
Old 01-10-2009, 10:31 PM
80351's Avatar
80351
80351 is offline
I have a Kodiak woodstove in what we call the computer room which use to be the garage at some point. But in the living room is a fullsized fireplace that doesn't have an incert in it but thick glass doors to close it off and a radiator that goes accross the top of the firebox so you don't need a big fire to heat it up and it does work rather well, that and sealing fans through out the house to push the air down.
  #1536
Old 01-10-2009, 10:33 PM
drunkdave's Avatar
drunkdave
and the worst part is I filled it up this morning on the way to work. so if I drop the tank tommorrow it will have about 28 gallons in it.
cool, that will save me some time and money then, i guess I'll just take a grinder to the bumper and make the notch a little bigger so I can fit one in there.
  #1537
Old 01-10-2009, 10:38 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
ours was built with the house... had we known it was gonna be a waste to use it we would have told them no to the fire place... now its blocked off with 3"Styrofoam blocks, thats attached to some insulator board and felt glued to the back of that.. and thats all stuffed into the recess of the fireplace where the inserts at... that way its not still sucking the heat or a/c out of the house... infront of all that is 2 big and full book cases..
  #1538
Old 01-10-2009, 10:41 PM
80351's Avatar
80351
80351 is offline
Me think thats what the flu is for
  #1539
Old 01-10-2009, 10:42 PM
80351's Avatar
80351
80351 is offline
That's gonna be a Beocth to get out
  #1540
Old 01-10-2009, 10:45 PM
80351's Avatar
80351
80351 is offline
Well guys got a few other things to do,
Nite all
  #1541
drunkdave's Avatar
drunkdave
what i was thinking anout doing is, amkeing a frame out of 2x4's to support the skid plat, then put 2 floor jacks under it. unbolt the skid plate and raise the truck off of the tank with a 2 post lift.
  #1542
Old 01-10-2009, 10:46 PM
drunkdave's Avatar
drunkdave
night dave
  #1543
Old 01-10-2009, 10:49 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
just me and dave now...
  #1544
Old 01-10-2009, 10:50 PM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Agreed. If we figure that a gallon of gas is the same as a gallon of water, Drunk Dave will be looking at 230 lbs. of fuel weight alone, so figure another 50 or so for the tank. Either way, not my idea of fun.
  #1545
Old 01-10-2009, 10:51 PM
drunkdave's Avatar
drunkdave
yeah, just the 2 of us, and Im gonna head out. Im gonna grab a couple hours of sleep and I will be back around 6am.
Quick Reply: DE January Chat Thread All Welcome
