Buying a new SD 5.4L V8 or 6.8L V10?
You will get a ton of input on this one. I know a number of people who drive the v10 work trucks. When towing they get almost as good mileage as the v8 and I suspect better mileage in some circumstances, but when not towing or hauling the mileage is a much wider gap between the v10 and v8. Also, it depends on the driver. For instance, I have a heavy foot and I dont get great mileage in my v8 and get much worse mileage in the the v10 on the occasions that I have driven it.
In my opinion, if you plan on towing a lot or you want to lift the truck and put substantially larger tires on it, I would suggest going with the v10, otherwise the v8 is just fine.
It basically boils down to your preferences and what you want the truck to do. I own a 5.4L, tow a 28 foot enclosed car hauler with 4500 pounds of car in it (around 8000 pounds total load). I love my 5.4L.
Others think the 5.4L doesn't have enough power and will tell you to get a V-10.
All I can recommend id that if you anticipate towing over 8000 pounds on a regular basis, you should probably get the V-10, but in either case test drive a V-8 and a V-10 Super Duty abd decide for yourself.
No superchargers for the 3V V10 that I know of. There are a few for the 3V 5.4L.
If you're looking for a 08+ gas Super Duty then I won't even get into the MPG because it doesn't matter. Any mention of it is silly, IMO.
Bottom line, and I posted to your same thread in the V10 forum, or a mere $600 you get 62 more horsepower and 92lb.ft. of torque.
Hardest part may be finding a V10.
True Dat! Earlier this year I was going to buy a F350 SD and I could not find a V10 to save my life. Everything sitting on dealer’s lots were diesels. I was able to find 2 V10, but they were stripped down work trucks, and i mean stripped down.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I had my dealer do a dealer search and they could not find a F350 Lariat Crew Cab with a V10 anywhere on the whole east coast. I was told that I would have to order one if I wanted one. I've since decided to keep my Ex for a couple more years, hopefully they will still be offering the V10 when I'm ready. Since I've stopped looking I did run into one 08 F350 with a V10 from TX, but it was 2wd.<o></o>
<o></o>
Good luck,<o></o>
<o></o>
<o></o>
Good luck,<o></o>
Bah Hum Bug! Go to Autotrader.com and search for 2008-2009 F250 with V10 and 4x4... they are all over the place!
This was a 300 mile radius of Charlotte, NC:
Find Your Car: Ford F250 Listings Near Huntersville, NC - AutoTrader.com
They weren't all over the place this time last year. I wasn't looking for used ones at the time and I did say that as soon as I stopped looking I found some. I guess when diesel started to crest the $5.00 mark then dealers started ordering a few V10's to have on hand.
I've never figured out why some dealers or those within a region stock truck configurations different from others. The only '08 F250s that I could find in San Diego configured the way I wanted were either diesels or V10s. The overwhelming majority were SuperCrew diesels. Even stranger was a complete lack of '09s in Southern California while there were an abundance of them in Phoenix, AZ.
