1978 - 1996 Big Bronco
err =/
Old Dec 30, 2008 | 11:29 AM
Cdy1's Avatar
Cdy1
err =/
ok iv asked many times and you guys have help alot but i stil have the same prob with the shifting in my bronco, 95 5.8 e4od, i know the wires for the speed sencor r 16g what color are they under the dash/hood and does any1 have a diagram i could download (im going to replace the wires from the sencor to the cpu, cpu to trans)
Old Dec 30, 2008 | 11:31 AM
Cdy1's Avatar
Cdy1
might i add when it "acks up" if i smack the dash it fixes it 90% of the time
Old Dec 30, 2008 | 08:49 PM
BroncoGurl's Avatar
BroncoGurl
'95 E4OD Wiring Diagrams
http://fordfuelinjection.com/files/bronco_1995_30-1.gif
http://fordfuelinjection.com/files/bronco_1995_30-2.gif
Old Dec 30, 2008 | 10:34 PM
greystreak92's Avatar
greystreak92
Try NOT sending members away from one site when the answers can be had right here. Sorry but its not like some other site knows more nor do its members. This question applies to every Ford fullsize 4WD truck of this vintage.
Um, you may have answered your own question with your "added note". Considering that you said it "fixes itself" when you smack the dashboard you might try checking the connection and the condition of the switch in the dashboard. The Haynes service manual has fairly accurate wiring diagrams. I have always been able to accurately trace electrical system issues with them.
Old Dec 31, 2008 | 10:21 AM
Cdy1's Avatar
Cdy1
iv had everything apart more then once, everything looks fine i even replaced the speed sensor, and when it shifts hard sometimes the od light will give the code some times it wont, but the code is speed sensor falt
Old Dec 31, 2008 | 12:06 PM
SpectreZ91's Avatar
SpectreZ91
Have you checked your fluid?
Old Dec 31, 2008 | 01:43 PM
bigunred's Avatar
bigunred
Did you use a new speed sensor or used. Do you have stock gearing and tires, a shift kit,
have you tried to disconect the battery for 15 mins or more? what all have you done do you have a aftermarket chip?.
Old Dec 31, 2008 | 03:16 PM
Cdy1's Avatar
Cdy1
yes everyhing is stock the sensor was used and i changed the screen and fluid not to long ago
Old Dec 31, 2008 | 04:17 PM
bigunred's Avatar
bigunred
I would try a new sensor, did this start befor or after the filter change. you might try changing your overdrive switch also if a smack to the dash makes it work.You can pm me the exact dillima and remidies youve taken so far and i might be able to help ya better. Jay
Old Dec 31, 2008 | 09:40 PM
Cdy1's Avatar
Cdy1
its been doin it for about 10 years, (my parents had it) i got it last year and iv been tryin to fix it ever since
way2crazy58
2004 - 2008 F150
Oct 27, 2012 10:51 PM
Wayne Soini
May 1, 2012 12:11 PM
benthere
Dec 15, 2010 09:37 AM
Txquadhunter24
Dec 19, 2003 06:43 AM
ransnan
Mar 26, 2002 06:35 PM
