Expedition "Evap system not Responding"
Old Dec 29, 2008 | 08:44 AM
mkboger's Avatar
mkboger
Have a 2001 Expedition 5.4L. Took for emmisions test and unit was rejected. Shows "Evap system not responding". Any ideas what may be causing this?
Old Dec 29, 2008 | 04:31 PM
projectSHO89's Avatar
projectSHO89
Need the actual Pxxxx fault code if one was present or whether it was a simple not ready condition for the evap monitor.
Old Dec 29, 2008 | 05:34 PM
alloro's Avatar
alloro
Make sure your gas cap is on correctly and is tight.
mkboger's Avatar
mkboger
"evap system not responding"
No code is listed. Just purchased and Tried to have emmisions test done on vehicle. Test was "rejected" due to evap system. Have checked with auto xray scanner. When scan is done shows that evaporative system test "not completed".
Was told by guy I bought the truck from that battery had just been replaced. Battery is new. I know that when truck loses power it will have to be driven before all systems respond. Have now driven about 150 miles and when scanner is used still shows evap test to be not completed. Would be thankful for any help.
Old Dec 30, 2008 | 08:18 AM
projectSHO89
You have a simple "not ready" condition due to the recent battery replacement.
The EVAP monitor will run eventually in its own sweet time. My Contour, for example, finally ran after two months during winter a few years back. It is extremely difficult to get the right running conditions to launch the test during cold weather as one of the parameters is an ambient air temp above 50F.
Depending on your state, you may be able to pass even with one or two "not ready" monitors. Check with your state's governing authority (go to their website and read the criteria) to see is such an exemption exists and the tester was unaware of such an exemption.
Steve
Old Dec 30, 2008 | 08:35 AM
mkboger's Avatar
mkboger
Thanks for the help. Will continue to keep checking.
Old Dec 30, 2008 | 10:34 AM
anfo's Avatar
anfo
This happened to me last year, read this page and follow the instructions.
Ford Motor Company Driving Cycle
Takie it to the local parts store and have it scanned when you finish to ensure all the monitors are set before going back for inspection, mine went about a month and a half before I found this and it took me a coule tries to get it right (try to find a big empty parking lot near an interstate on ramp, I used a huge local truck stops lot).
Old Jan 13, 2009 | 08:46 AM
mkboger's Avatar
mkboger
Took about 2 weeks of "normal" driving and evap system is now responding.
Warren Hart
Sep 30, 2016 06:35 AM
diverdon55
Aug 19, 2016 01:14 AM
dman776
Jul 25, 2016 01:03 PM
wildbill1963
Escape & Escape Hybrid
Sep 10, 2010 08:30 PM
BURNSTOUGHFORD
1997 - 2003 F150
Jul 7, 2008 09:44 AM
