8ply vs 10 ply tires
Buying a E-350 Ford van 6.8L 4:11 rear and having it 4x4'd. Stock tires are LT245/75R/16E ( 10 ply)...Want to install LT 295/75R/16D 8 ply) BFG all-terrain TA KO. Sidewalls concern me since the off road travel could cause a problem for them. Tires should change rear to a 3:75 if my math is correct. Any thoughts on the reduction in ply or my math ?? I guess I would then need a chip change for the shift pattern, fuel and other changes.
I don't think you will have any problems with the BFG AT's they are a purpose built off-road/hi-way tire. If you want even stronger side walls you will have to go with a Bias-ply tire.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205
And a '68 Bronco 289 v8 , NP435 , Dana 20
Eric
farmallmta
03-29-2015 04:16 PM
kehinnc
07-27-2011 09:29 AM
fordgirl<3
23
12-30-2010 11:58 AM
mechelement
23
09-01-2009 11:33 AM
