Sponsored by: Real Truck
code HELP
Old Dec 27, 2008 | 10:53 AM
Alaska Tony's Avatar
Alaska Tony
Question code HELP
Ran code check on my truck after problems and recieved code P0320 "Ignition/dist engine speed input circuit malfunction". Hoping someone out there can help with what that means and what repairs need to be made. Would greatly appreciate any help, THANKS
Old Dec 27, 2008 | 12:11 PM
dchamberlain's Avatar
dchamberlain
It would help to know more about your truck. Year and engine, etc.
Old Dec 27, 2008 | 12:16 PM
Alaska Tony
My truck is an 1999 F-250 V10. It started on night sputtering and bucking and then died. It would start and idle ok but as soon as gas was applied it would sputter and either catch itself or die. Replaced the fuel filter and pump but it kept doing it. Connected ODBII and received a couple codes that led me to replace two bad coil packs and all the spark plugs while i was there. That still didn't solve the problem and now the only code is The above code i mentioned. Thanks
Old Dec 27, 2008 | 12:43 PM
dchamberlain
I have a diesel, so my service manual doesn't even show that code. But, just guessing from the description, I would say there is a cam or crankshaft position sensor that is malfunctioning.
Sorry I can't be of more help than that.
Old Dec 27, 2008 | 05:44 PM
PowerStrokeHD's Avatar
PowerStrokeHD
This is what I was able to dig up on the DTC...
P0320 - Ignition Engine Speed Input Circuit Malfunction
Description...
The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred.
Possible Causes...
Loose wires/connectors
Arcing secondary ignition components - i.e. coil, wires, plugs
Onboard transmitter (2-way radio)
tlcsr66
May 14, 2014 04:08 PM
Bearpaw357
2004 - 2008 F150
Jun 9, 2012 09:20 PM
Lonewolftx
Nov 11, 2011 04:03 PM
Wakeboarder141
1978 - 1996 Big Bronco
19
Oct 31, 2004 11:50 AM
labtech
1983 - 2012 Ranger & B-Series
Oct 30, 2004 01:22 PM
