the truck bed's come close to falling off.
the toyota and chevy just about shake apart, The All-New 2009 Ford F-150 Pickup Truck | Ford Vehicles click on Durability,left side bottom.
You Guys don't get it. Frames should twist a little. They are designed to twist, to prevent breaking, and improve traction by keeping the wheels on the ground.
They should load the trucks with 500-600 lbs and do the test 100 times. Then inspect them for damage, loose connectors, etc.
Would You'd consider an 85K lb concrete mixer to have a weak frame? I drive them thru uneven work sites and have seen them twist 30 degrees. Wow, what a weak frame!
When my friend was buying his Scion, I was looking at the tundra in the showroom. They had a frame display to show how "tough" the frame was. I could bend the upper and lower parts of the "c" channel together with my thumb and forefinger....... I was NOT impressed. I don't think I'd feel safe hauling my family in a truck with a frame that weak, let alone groceries.
Whatever. This is about as lame as the Tundra commercials and the new Ram commercials.
It's a BS test made up to highlight a pretty unrealistic situation. Nobody is going to do that.
I'll go along with saying this makes the F150 better when you all start saying that 0-60 times make other brands better. At least many people will actually find themselves flooring thier trucks up steep on-ramps under heavy loads. Nobody will be driving 25MPH over anything like that.
Yes it looks like the Ford won, but I don't care as it's a stupid test.
Mike
Mike
It was a test designed and controlled by Ford to make Ford look the best. All of them make up tests that show their truck is the best.
This was just one of them. The mileage test is even worse. Ford more than likely used the 4.6 2V with the 3.15 gearing. Who else makes anything that weak in a V8? How fast were all the vehicles going?
Again another Ford controlled test.
I think it does show the frame quality though, and shows it is top notch.
Im sure you will get flooded with guys saying stuff like how the frame is more important then more power, and in some cases they may be right, but I think your bang on the nose.
I think it adds to the overall package of a f150 too. Just give us that bigger motor Ford, and ya have a truck that will smash the competition!
