Sponsored by: Real Truck
Shifter Play F350
Old Dec 22, 2008 | 09:32 PM
pat13b's Avatar
pat13b
Shifter Play F350
Hello,
I'm sure this topic has been covered several times, but I tried to do a search and the search engine does not seem to be working, Anyway Can someone tell me how difficult it is to reapir the shifter in a 1999 F-350 Automatic.
I seem to recall this problem in fords many years ago and was surprised that when my son purchased his truck the other day, it too had this same problem.
The shifter is sloppy and seems to not lock into the different gears as well as it should.
Thanks for any help you can give on this.
-pat13
Old Dec 22, 2008 | 09:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Underneath the steering column are two Torx head bolts. They hold the shifter to the column. They're loose. Find and tighten.
Old Dec 22, 2008 | 09:55 PM
pat13b's Avatar
pat13b
WOW, that sounds simple enough.
Thanks for the quick response.
-pat13b
Old Dec 23, 2008 | 03:08 AM
Move over I'm coming's Avatar
If that doesn't help.
The aluminum shift tube and plastic bushings will need replacing.
This takes about an hour and are available from the dealer.
You pop off the shroud from the column (un-screw then pull apart)
It is easily accessable with a few hand tools once you see whats there.
Old Dec 23, 2008 | 08:41 AM
pat13b's Avatar
pat13b
Thanks for all the advice. This is a great forum.
-pat13b
Old Dec 24, 2008 | 09:28 PM
firemediceric's Avatar
firemediceric
For me, it was none of the above. In my case it was a plastic plate on the left side of the transmission where the linkage connected. Simple enough to fix once it was identified.
With the above suggestions you should now be able to trace the problem no matter where it is from the steering column to the transmission. Let us know how you make out.
Old Dec 25, 2008 | 11:23 AM
pat13b's Avatar
pat13b
Thanks I will look at this also. I did find that the upper bushing had slipped down. I re-positioned it, but I plan to order a new set. I'll also take a look at this plate.
Thanks very much
-pat13b
Old Dec 25, 2008 | 11:35 AM
swaybar's Avatar
swaybar
Thanks very much
-pat13b
i did both of these routes but still had a sloppy shift that i was about to give up on. though either of these could rememdy your issue, on mine i followed on the end of the shifter "under the column" i followed the thin metal "wire""cable" thats on a hook to a bracket that had two tourqe bolts that were loose. you can't see the screws from looking up-its up and look back towards the drivers seat.
mine were extremely loose and i was so happy to find this problem cause it tighten everything up like new.
mine was getting so bad i had no low1.
good luck
Jumpdummy
15
Oct 8, 2012 11:43 PM
mgraveman
Modular V8 (4.6L, 5.4L)
Jun 12, 2006 07:53 AM
Redneckerson
Mar 9, 2002 06:22 PM
