5.4 intermittent rattle from valve cover
Truck has approx 90K, no engine or other issues to date. Engine performs well with no issues other than intermittent rattle coming from pass side valve cover- specifically near front of engine. Oil cjanged regularly with 5W-30 oil. Sometimes noise occurs at startup then goes away, other times it starts after driving for a while. Any info appreciated.
I took my truck to the Ford dealer today. They said the problem is the cam phaser (pass side) but there was no rush to fix it. The mechanic said the noise is irritating but it won't hurt to keep driving it. The did have a cam phaser in stock so I got to see what the part actually looks like. Mech said the updayed cam phaser has different oil porting to prevent the current problem. The price for the part was quoted as $250 - anybody have any ideas where to get the part any cheaper or is that the going rate? I'm very confident I can install the cam phaser on my own but the part cost is a kicker.
Thanks for the help
Thanks for the help
it will be hard to install the phaser without the proper tools.you will need the wedge that holds the chain tensioner apart to releave thew prssure off the chain and the tool to remove the lash adjusters.the 2 tools can be bought but cost about 3-4 hundred dollars.there is a support pin in the origanal phasers that is just a hollow role pin and the redesigned phaser has a solid pin in it.
dmenkhau
01-27-2016 04:16 PM
genscripter
05-01-2015 02:00 AM
handyman43358
02-13-2013 07:16 PM
