1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
03 F250 Overdrive Opinion with Slide in Camper?
Old 12-22-2008, 11:11 AM
orng1's Avatar
orng1
orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
Just keep posting in your own thread 'til you get those 25 posts. How about post a few pics of your turck, one at a time.
Old 12-22-2008, 12:08 PM
Catch This's Avatar
Catch This
Catch This is offline
Catch This is starting off with a positive reputation.
Thnx for the heads up on the need for 25 posts. I dont want to junk things up so I will attempt to find something constructive to say in the various forums.
Old 12-22-2008, 12:47 PM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Originally Posted by Catch This View Post
25 posts ....makes sense, I only have 12...
and yes I have the 3.73 limited slip differential.
Thnx
Yeah the 3.73s hurt and load the engine down a lot. Can't wait till I can get the cash together to swap to 4:30s and some decent diffs on my truck.
Old 12-23-2008, 07:09 AM
Catch This's Avatar
Catch This
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 11">****** name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5Cbelloj%5CLOCALS%7E1%5CTemp%5Cmso html1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Thanks again guys. I had an interesting & informative conversation with Pocono on the phone. Our sets ups are pretty identical with the major difference being he has a 4.10 rear end vs. my 3.73. He runs about 500RPMs more than I at about the same speeds and our MPG is pretty much the same. I would have thought with the higher RPM’s there would have been a greater difference in MPG. Regardless, it sounds like the use of the speed control is not recommended when hauling the camper and Overdrive gets turned off on hills.
<o> </o>
I appreciate the responses and feedback.
Old 12-23-2008, 07:47 AM
dkf's Avatar
dkf
dkf is offline
He should not run more than 200 rpm more in OD with his 4:10s vs your 3:73s. (If same tire dia is used)
HMS
03-02-2014 02:41 AM
BigSix1
23
04-19-2013 12:37 AM
hard3
07-11-2009 07:23 PM
smote
Modular V10 (6.8l)
04-02-2009 06:21 AM
Quick Reply: 03 F250 Overdrive Opinion with Slide in Camper?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
