High Temp 4 degrees & decreased MPG + loss of power = ???
As for the truck, it is a 2000 F350 7.3 PSD Dually. I have had the truck about a year. It has about 120 K miles. Only major problem since I had the truck was loss of the water pump. As for me, a wantabe/newbe mechanic so just learning.
The last two tanks, my MPG has gone from 15-16 MPG down to 10-11 MPG. I have recleaned the EBS tube, but it looked fine. I put in a new oil, oil filter, and a new fuel filter the week before my mileage tanked. The truck seems light in power, and the engine sounds "tinny". It is almost as it is lugging.
As far as other factors, since this has happend, the weather has gotten a might bit chilly ( high of 4 degrees F, low -6 to -10 degrees F ).
Just for a reallity check, especially since I have just been running around town recently ( too many idiots on the road that have forgot that white stuff means slow the same as it did last winter ), I did a highway road trip. I drove 90 miles and put 9.2 gallons back in the tank. It was not exactly highway type driving in that, even with my constitution, I was getting a pucker factor at about 45 MPH, which was way too fast for the conditions. The trip was continous though and not start/stop driving. There was no place I could safely stomp on it without ending up over an embankment, but the truck did seemed power challenged.
Any hints/help would be appreciated.
TIA, Fred ( jyblood@nwi.net ).
I always see a drop in MPG in winter as well. Our stations change over to winter blend about Oct/Nov. Not sure about your area but the winter stuff yields lower MPG's Someone a lot smarter than me can explain that. Plus, a big factor for me is the truck idles a bit more to warm up. Diesel Kleen in the white bottle is a good additive for winter fuel and preventing gelling.
Problem found:
Snout on the air intake box was 90% plugged with snow/ice that was frozen solid. Dethawed and the truck is running good. Guess it is time to upgrade to a AIS.
Thx's for the help, Fred ( jyblood@nwi.net )
