Battery Brain/fuse holder/4ga wire.
I have a device called a battery brain. It disconnects the battery when it sits at 11.8v or lower for a few seconds. It test out fine on my "bench", an old optima that holds 12.2v and an old Southern VP red/blue light bar. I watched the voltage, it had 12.1v before hooking anything up. I put the BB on the stud, then moved my DMM leads to switched side of the BB and the ground post, still 12.1v. I then hooked the light bar up just like the DMM. It ran for about 5 seconds and the BB clicked, shutting off the bar and the DMM read 0v. I put it on my truck again. The power dist is set up as so (using tsunami parts.) The alternator has it's own 1/0 wire going to a 250amp fuse (230 amp alt), 1/0 between the fuse holder and the + battery terminal. The Accys run from the battery terminal to a 200 amp fuse then to the battery brain all with 4ga wire to a distribution box with 60a fuses. It does not work right, it clicks but it doesn't disconnect the power. It has a solid ground, and I tried leaving it hanging so my mount isn't the trouble. Anyone have any clues about these things and if they dislike fuses?
strokin'_tatsch
32
06-12-2013 12:21 PM
Matthew in SD
01-21-2012 11:45 PM
TheKirbyMan
15
12-05-2010 11:26 PM
TheKirbyMan
'80-'86 FAQs (Frequently Asked Questions)
12-05-2010 11:26 PM
