06' drive shaft center bearing
Just to update, I took the drive shaft to Clinard's Shop in Nashville (615-242-4253) and $400 later I have a standard carrier bearing on it. It was a bit steep but he had to cut it up and put on a new End Yoke, Stub shaft, and replace the strap, u-joint and of course the bearing.
Now if it goes again I can get the bearing anywhere and it'll be a $50 fix and I won't have to worry about Ford wanting me to buy a new drive shaft again.
He did tell me that the bearing was about 3/8 shorter than the old one was so I would need to check for vibration after it was installed and may need to space it out that 3/8. He said it may or may not be a problem.
max harris
08-07-2016 04:01 PM
Gwilkrrs
6.4L Power Stroke Diesel
06-27-2016 10:21 PM
trentmw
02-16-2006 04:38 PM
