won't turn over
Old Dec 16, 2008 | 05:43 AM
little truck's Avatar
little truck
won't turn over
I went to get in mt 94 ranger and tried to start it but it just clicked. I got out my charger and after it charged it still just clicked. I see no corison on the battery. Could the solinoid be bad?
Little truck
Old Dec 16, 2008 | 06:41 AM
Pablo-UA's Avatar
Pablo-UA
easily! be sure your truck is on 'P' and try carefully jump solenoid lugs (8mm lugs). If starter motor works, just change solenoid.....
Funny to see how you will open hood to start engine every day driving to work! )))
Old Dec 16, 2008 | 07:47 AM
little truck
Thanks for the advice Pablo
I just went out to take a look at the battery again. i remove the + terminal and saw a little oxidation no corision, i clean it up and the truck is now running.
little truck
ps
i would have tried this first but it is cold in the buffalo area today and was looking for any answers before i bundled up to do the repairs.
Little truck
Old Dec 16, 2008 | 10:07 AM
wendell borror's Avatar
wendell borror
Yeah, a lot of times when such problems occure, it's a battery or cable related problem. I know what you mean when it's cold, no one feels like massing around with a vehicle.
Old Dec 16, 2008 | 05:22 PM
matt's2.9STX's Avatar
matt's2.9STX
The clamp could have loosened a bit too from weather & vibration. Sometimes that's all it seems to take if you're in a hurry. Just don't over-tighten it. That could also explain oxidation insulating the post for different circumstances. Always seems to be the negative side. I put a Scosche "platinum" terminal (car audio) on my negative side. Not much good for boosting others though. Stays tight better & then the plastic-handled combo wrench set easier to stash & work with 20 degrees below freezing. Also easier to plug goodies in, change fusible links & such.
O yeah, is the battery hold-down in place & snug?
corbit96
Sep 16, 2014 06:56 PM
92will460
Jan 17, 2014 11:59 AM
bluescrew
Nov 6, 2009 09:00 PM
reflections
Jul 1, 2009 01:55 PM
cjcathey2002
Dec 10, 2003 07:44 PM
