dana 60 front
Old Dec 13, 2008 | 05:20 PM
lucky no. 7's Avatar
lucky no. 7
dana 60 front
has anybody done a dana 60 front swap on here in a 94-97 f-250? i'm wanting to get rid of the ttb crap and whatnot, cant afford one around here right now, is there anything else they came in that i may be able to maybe weld some spring perches on and run it or is it only a ford front deal?
Old Dec 14, 2008 | 09:59 AM
Opossum's Avatar
Opossum
IMO you are better of going Ford for your dana 60 nobody else used them as much as ford in fact new superdutys are still dana 60's. 85 1/2 was the first year to get a direct bolt in dana 60, until 92 they wear also kingpin which is stronger instead of balljoint. Best deal is generally to find a cheap donor truck that has one so you can get everything you need from the same truck, and you'll pay less then just buying the axle from someone who knows what there worth.
redroad
15
Nov 8, 2014 09:09 PM
4wydnr
Feb 28, 2012 07:12 AM
fordsford11
Washington Chapter
Jan 22, 2012 12:41 AM
abendx
Aug 12, 2002 01:53 PM
