2003 Ranger Fuel Pump Replacement
Tested my fuel pump by hotwiring it ... it was a no go.. so I need to replace it.
Bed is off and getting the lines off the pump assembly is done.
Problem is that the "mason jar" ring that holds the pump into the tank doesn't want to move...
Mitch_c
- Is there a locking mechanizm?
- Should it just turn off?
Mitch_c
I used a large 'water pump' pliers. They have a slip-jaw that you can get wide enough to reach from one corner of the retaining ring to one corner of the tank, and squeeze slowly. You don't have any impact to cause sparks, and can apply just enough pressure to unscrew the ring.
tom
Why is there a horn in the back in the 4th picture?
tom
tom
tom
This is not a horn, This is spare lift. This tube made like a horn helps to fit bar to turn spare tire lift.
mitchc
1997-2006 Expedition & Navigator
33
06-23-2015 09:08 AM
mitch_c
1983 - 2012 Ranger & B-Series
08-06-2014 10:57 PM
Mitch D
09-23-2003 07:23 PM
