need advice on wheels and tires
Honestly, I have 1/2 ton fenders and a standard axel, so I don't have any good advice. I just wanted to bump this back up to the top so you could get some more help!
Good Luck,
Julie
Try Stockton Wheel. They have a killer website with a form to fill out with measurements so that you can get the right setback the first try. Good luck, Jag Stockton Wheel Service - Custome Wheels
If you want to see what 15x8's (or they might be 15x7) look like I have a set of slotted mag wheels with tires mounted that you can borrow to trial fit.
I will probably put the slotted mags back on my truck eventually as the chrome is peeling on my Cragars.
If you want to play with them let me know.
Bobby
Bobby
Cool, just drop me a line if you want to try them
The 16's would probably fill up your larger fenders better....depending on the tire choice. I have a set of P235/15 radials in the shed that I will eventually mount on the slotted mag wheels and put on my truck. Right now I'm in the process of wearing out the bias ply tires that are mounted on my Cragars.
Bobby
Bobby
I definately have both wheels and tires on my truck - 4 of each of them!!!!! I tried driving without one once but it made a lot of sparks so I definately recommend you don't try that!
Good Luck,
Julie
Good Luck,
Julie
