Any Mercury stuff on this site?? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-02-2009, 09:54 AM
56panelford's Avatar
56panelford
56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Originally Posted by Michigan Rick View Post
I have made a gallery of my Mercury stuff minus any paper stuff I have and pics of my driver.
Michigan Rick
Hi Rick, I noticed in your gallery a picture of the location of the spare, did you put it there yourself or was that the factory location. I had a 56 back in 69 that had the same mount but on the opposite side, I have inquired a couple times on hear with no response as most seem to have been underneath and between the frame rails. This where I plan to install mine but would still be interested if it was factory.
  #47
Old 01-02-2009, 10:12 AM
Michigan Rick's Avatar
Michigan Rick
Michigan Rick is offline
Michigan Rick is starting off with a positive reputation.
56panelford......
Mine was underneith...but I made my bracket to hold the tire.
Michigan Rick
  #48
Old 01-02-2009, 11:20 AM
Greg M-47
Greg M-47 is offline
Greg M-47 is starting off with a positive reputation.
Hi Rick. I haven't seen very many Mercury panels . Very nice looking. I'm another merc fan. Justjoined this forum. I've got a 1949 M-47 that I've started on. Would like to find other '48-'50 M-47 owners to compare findings from my tear downs with.
There is a red Merc panel down in Florida that I saw some pictures of. Real nice to see yours. Thanks for the picture.
Greg
  #49
Old 01-03-2009, 06:04 PM
Greg M-47
Hi Rick, Got your message but guess I don't have the okie dokie to go to it to answer so I'll answer here and hope you get this message.( Tried a couple times and no go ) I've heard about the SOCP. I have been a regular at the Arthur truck show for the last few years when I manage to get the time off.
Brights Grove is just across the river from Port Huron and up the lake 10 minutes. A long way from Ottawa. I'm thinking of joining the west coast club. Their meetings are held in Grand Bend, Ont. which is about an hour north for me. I just need to fit it into my plans. And Dean seems like a good guy. Might even have some parts I need. Hope you get this and it answers your questions.
Greg
  #50
Old 10-04-2009, 09:50 PM
esco0502's Avatar
esco0502
esco0502 is offline
esco0502 is starting off with a positive reputation.
I just purchased a 1946 Mercury 1 ton pickup all in pieces...Im glad there are Merc friends around! Cause I'm going to need lots of help...LOL
Pablo
  #51
Old 10-05-2009, 08:45 AM
Greg M-47
Hi Pablo, Glad to hear of another Mercury truck owner on this site. Okay so now you just have to tell more about your Merc. What kind of shape is it in and how did it find it's way to Vero beach FL ??
Greg M-47
  #52
Old 10-05-2009, 11:39 AM
esco0502's Avatar
esco0502
esco0502 is offline
Well I found it in Melbourne Fl. I bought it from a guy that had it sitting in a storage unit for a while. He had it all apart in pieces because he had started on the project but the friend he had that was helping him moved or something, so the project stopped. He listed it and I found it. I went to look at it (little overwhelm seeing it all in a million pieces) but was happy to see that everything was reading to be rebuilt. Cab and frame are all primed and he had purchased all new fiberglass pieces. So the running boards and all fenders are all new! So I had started rebuilding the rear to get it ready to put back on the frame but I ran into a problem where one of the drums is bent and no one sells a new one for a 46 1ton pickup just 1/2 and 3/4 ton. So now I have to find what donor rear I can use on this truck to continue on the build. Any suggestions?
pablo
  #53
Old 10-05-2009, 01:52 PM
Greg M-47
Off hand I haven't got an answer to your problem but I'm sure someone on here will be able to give you some advice. Have you got all the Mercury trim with your truck ? The grill pieces seem to be getting pretty hard to find for the '46-'47 Mercs. Hopefully someone will help you with an answer to the rear end problem. Good luck with your truck.
Greg
  #54
Old 10-05-2009, 05:22 PM
esco0502's Avatar
esco0502
esco0502 is offline
Missing 1 center piece of the grill and the grill needs lots of work.
Pablo
  #55
Old 10-05-2009, 08:28 PM
vintage tin's Avatar
vintage tin
vintage tin is offline
vintage tin is starting off with a positive reputation.
pablo
what are you plans for your merc?i have a 50 m-68,the 60-72 f-250 is a straight swap for me.might be a good thing to check out for you.
how many would you like to see,this is my 50.
this is a 52 m-3 next to my work.
pablo ,is your bolt pattern 5 lug or 8 lug?
btw,there are lots of old mercs in and around lethbridge alberta.
if you want more pics let me know.
  #56
Old 10-06-2009, 09:02 AM
esco0502's Avatar
esco0502
esco0502 is offline
Im trying to restore the 46 and use it pretty often. Mine right now is a 5 lug pattern. So you are saying I can use a 60 thru 72 f250 as a swap for my rear and front axle?
pablo
  #57
Old 10-06-2009, 07:51 PM
vintage tin
pablo,this forum is 48-60 so im not sure on the 46.
i do know that the 48-50 front frame is narrower than 51f-1 and up,how ever i did get a 53 complete front axle for cheap,all i did was swap the backing plates and hubs had to run smaller hard lines for the brakes how i have the 5 on 5 1/2 bolt pattern on the front.the 51 f-1 to 60 front end is about 3 inches wider that 48-50 so i couldnt swap the hole axle.
how they say the ford 9 inch is a direct bolt in for these trucks(1/2 3/4 and 1 tons)but i have not done this as yet,i dont know if the 46 is the same.
i hope this helps some.you may want to try the 47 and older forum and see if they can help you better.but these guys and gals here are pretty smartwhen it comes to our trucks just not sure if it will cross over to yours.
  #58
Old 10-06-2009, 10:18 PM
esco0502's Avatar
esco0502
esco0502 is offline
Thanks Roy, you are right, Im getting lots of help from great people in this forum. Very informative!
Pablo
  #59
Old 11-15-2013, 09:08 PM
canadianfalcon
canadianfalcon is offline
canadianfalcon is starting off with a positive reputation.
Anyone know anything about 1961-67 mercury panel vans? I've found one and am wondering how rare these things are. I can't find any information on them anywhere. Any help would be greatly appreciated. Thanks
  #60
Old 11-16-2013, 11:28 AM
51MercuryM1
51MercuryM1 is offline
51MercuryM1 is starting off with a positive reputation.
Building a 51 Merc M-1 as we speak. There are a few left up here it seems. I have come across others when I was looking for mine.
Quick Reply: Any Mercury stuff on this site??
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
