British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
Diesel tech in the South OK
Old 11-28-2008, 11:59 AM
mojoman's Avatar
mojoman
mojoman is offline
Question Diesel tech in the South OK
just as the title reads...I need some help with my truck and am located in Osoyoos...anyone know of a local "good" tech???
mojo
Old 11-28-2008, 03:35 PM
Zip's Avatar
Zip
Zip is offline
Send a PM to Val (warriormama) she is from Osoyoos as well. She may be able to point you in the right direction.
Old 11-29-2008, 09:45 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
Mojo, whats wrong with your truck? What year of truck is it? Maybe we can help
Old 11-29-2008, 12:06 PM
mojoman's Avatar
mojoman
mojoman is offline
'95 F250 4x4 7.3...I had it scanned and the codes were not critical...I have replaced the glo-plugs...GPR...injector o-rings...batteries...starter...fresh oil...fuel filter...I bought this truck in Oct...it ran good when warmed up...but needed help(ether) to start after sitting for more than 8 hours...fortunately the GPR was NFG so the PO didn't hurt the motor(I hope) and has since been fixed...no ether now...but still no start...I've cranked this motor forever over the past 2 days...no smoke...no fire...when it was running it ran solid...so I think its just something minor....as opposed to a rebuild situation...any and all help appreciated...I'm gonna post this then head to the shop and replace the NFG block heater...
mojo
Old 11-29-2008, 01:17 PM
preppypyro's Avatar
preppypyro
Well if ya replaced the glow plugs, and the gpr, you kinda took my suggestions!
Have you tested them though, to make sure the right current is getting there? I dont know what the specific values are, but if there is a wire(s) that maybe are busted or whatever, then that may be a reason that they arent working.
In the last few days have you tried at all with ether? Like Im wondering if fuel is for sure getting to the injectors, can you hear your fuel pump going at all?
Old 11-29-2008, 02:28 PM
mojoman's Avatar
mojoman
mojoman is offline
well...I'm off to shop with the wife....if it don't rumble when I get home I'm gonna disconnect the glo-plugs and give it a sniff of ether...
mojo
Old 12-01-2008, 06:08 AM
Zip's Avatar
Zip
Zip is offline
Well any progress yet?
Old 12-01-2008, 08:50 AM
mojoman's Avatar
mojoman
mojoman is offline
I installed the block heater and plugged it in for 3 hours...she now wants to start...I'm thinkin' air in the hoses etc from the injector install...the shop is inheated at the moment so I don't hang around more than a couple hours at a time...will be back at it this morn for a bit...
mojo
Old 12-01-2008, 10:12 AM
mojoman's Avatar
mojoman
mojoman is offline
Talking
Beastor Lives!!!!!!!!....3rd crank and she fired right up....did a quick 25km run and its a much better feelin' unit...it took me 1.5 months but I got it...))
mojo
Old 12-01-2008, 10:24 AM
preppypyro's Avatar
preppypyro
Good things come in time man! Good call getting er going, nice to have a properly working truck eh!
Old 12-01-2008, 10:28 AM
mojoman's Avatar
mojoman
mojoman is offline
u bettcha...
mojo
Old 12-07-2008, 04:40 PM
Saleenguy's Avatar
Saleenguy
Saleenguy is offline
The wifes cousin owns okanagan diesel injection in vernon.
Its rather far north from you, but she says they do great work.
Old 12-08-2008, 10:16 AM
mojoman's Avatar
mojoman
mojoman is offline
Saleenguy...would appreciate any contact info you have....its actually a nice afternoon drive from here...thanks
mojo
Old 12-16-2008, 09:47 PM
Saleenguy's Avatar
Saleenguy
mojo
Sorry I have been away working.
The contact if you still need it is Okanagan Diesel Injection Ltd. (Contact)
