Whats the biggest windshield wiper you can fit on the X
It does but it is a PITA to put on for our trucks. I would recommend that if you are already there, put it on THICK and a couple of times.
Just open the door and stand with your feet on the floor board leaning over the winshield and your body wedged between the door and A pillar. Piece of cake.
I am running 24" on the front and 18" on the rear. 18" is as big as you can go on the rear. Using Michelin Stealth wipers all around and was soooo impressed with them that I bought a set for the Windstar. This will be the second Michigan winter w/the wipers on the Ex and first with the Windstar. So far soo good.
26" / 24" on front; 18" rear
From here: https://www.ford-trucks.com/forums/1...l#post11314017
I bought some of the Goodyear Assurance blades from Costco for $9ea and after a couple of times heading back into the store and test-fitting, here's my impression:
The 'Assurance' seem to have a less strong spring action holding them to the window than my girlfriend's Bosch Icons (comparing similar lengths), but they are a great value for the price. I have had no trouble with them lifting at 75mph.
I have some photos and will post them when I can, and hopefully a follow-up after some dirt has built up so you can see the wipe pattern.
- Driver's side - 26" - inside radius end 'swishes', but still wipes fine; won't wipe off thick snow at the ends; -may- be able to fit a 28" without interference
- Passenger - 24" - lifts slightly off glass near bottom outside corner when parked; minor smudging for the first 3-4" of arc-wipe; not worth going bigger
- Rear hatch - 18" - comes within a couple mm of the 3rd brake light at the top, but does not interfere; extends beyond the defroster when parked, so may get stuck if icy; the spring on the wiper arm isn't strong enough to hold this against the window consistently, and it skips a patch right above the pivot in the middle of the wiper about every 3rd wipe.
Need to get some good windshield wipers before a road trip and was looking at the Bosch Icons, I go to their site and put in the information for my Ex and all i get are maximum 20". How do I get 24" or 26"? Do I need to put information for another vehicle or am I better just going to my local auto supply store and just getting the size?
You're better off going to your local auto supply store or searching online for the specific size in the brand and model wiper you want to buy.
I bought mine from Amazon.com:
Driver:
Amazon.com: 28" Rain-X Latitude Wiper Blades: Automotive
These 2 are eligible for Amazon Prime - Free 2-day shipping:
Passenger:
Latitude 8-In-1 Premium Graphite Coated Wiper Blade, 26" : Automotive
Rear:
Amazon.com: Rain-X 5079275 Latitude 8-In-1 Premium Graphite Coated Wiper Blade, 18" (Pack of 1): Automotive
Driver:
Passenger:
Rear:
Any search using your specific vehicle is going to give you the OEM sizes exclusively. There won't be any "interchange" or "compatible" options.
#28
Whatever brand you want, just replace the 18 with 24 they are all
the same mounting hardware - in the same model/line of blades.
I put the rain-x fluid into my windshield washer fluid, then it gets
re-applied with each use, also helps get the bug bodies off,
since we all know we have a picture window-sized windshield.
#29
The 28" driver's side is awesome and the 18" rear fit's perfectly but the 26" on the passenger side is too long by about an 1" and should be the 24".
I saw all sizes up to 28" at Target for $18.49 while I was there today but you can get the 26" from Amazon for $17.47 with free shipping on Prime:
Rain-X-5079280-Latitude-Premium-Graphite 26"
Driver:
Passenger:
Rear:
Driver:
Passenger:
Rear:
#30
I have 22 inch blades in the front and a 16 inch blade in the back. For those of you running the 24s, is ENTIRE blade in CONSTANT contact with the windshield? Specifically on the passenger side. I don't want to be like the GMT900 trucks and suvs (Tahoe, Silverado, etc.) that have a portion of the wiper hanging off the windshield.
