MAP sensor
Old Dec 8, 2008 | 12:33 AM
Vinford's Avatar
Vinford
MAP sensor
Is the MAP sensor in the same place on a 91 diesel as it is on a 95?
On the firewall on the passengers side?
My neighbour has a parts truck and I looked for the sensor and could find it there?
Old Dec 8, 2008 | 05:25 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
I din't think we used a MAP sesnor in the 7.3IDI (like in the 91), just for the powerstrokes I thought.(like in the 95)
I got something that looks like a map sensor right below the right wiper arm area on the passenger side. The hose is broke off or there was never one there, just a gray clip with 3 wires. Not sure what it is though and never really though about it.
Old Dec 8, 2008 | 09:39 AM
Vinford's Avatar
Vinford
mmmmmmmmm the neighbours 93 has one.
Old Dec 8, 2008 | 11:55 AM
Dave Sponaugle's Avatar
Dave Sponaugle
That is a low vacuum warning switch, should turn the brake light in the dash on if you loose vacuum to power your brakes and run the heater controls.
With no throttle plate, the only vacuum an IDI diesel has is what is created by a dirty air filter.
Vacuum for the brakes is supplied by the vacuum pump, not the intake manifold.
Old Dec 8, 2008 | 05:26 PM
FORD MEGA CAB!!!
That particular sensor for the brakes I think is above the driver side wheel well, On mine anyway.. I almost know it its cause I broke the tit off where the vac line connects to the sensor while changing the water pump, now my brake warning light wont go out. Now I have to know exactly what that sensor is. Unless it has 2 sensors... I will do some reasearch and get a part number off it. Its got me thinking. Till then, good luck.
Old Dec 8, 2008 | 09:22 PM
Dave Sponaugle
Three wire going to it.
92 and later F series
Black = ground
Red yellow = ignition power
Dark green light green = output to dash light
Looks like the dark green /light green goes to ground to turn the light on.
RABS, brake fluid level, parking brake and low vacuum switch all tie together to turn it on.
Also looks like fuse 17 supplies power, but don't know what else that would take out.
Old Dec 9, 2008 | 08:14 AM
FORD MEGA CAB!!!
Simple enough, thanks for the info.
Old Dec 9, 2008 | 08:29 AM
LCAM-01XA's Avatar
LCAM-01XA
Actually folks, we do have a MAP-type sensor, only tis actually a barometric sensor to measure the ambient air pressure, I think the PCM uses it as an input in determine the shift schedule. In my truck that sensor lives on the firewall, between the A/C box and the engine air filter housing.
Old Dec 11, 2008 | 11:14 PM
ford trans tech's Avatar
ford trans tech
it is a BARO sensor and it is mounted on the a/c box below the right wiper
it is there for barometric sensor reading to aid in transmission shift scheduling
it is only on automatic E4OD vehicles
the 95 is a powerstroke and it is a manifold absolute pressure sensor for engine control fuction
Old Dec 12, 2008 | 12:23 AM
LCAM-01XA's Avatar
LCAM-01XA
Would you happen to know how exactly the BARO sensor readings affect the trans shift schedule? Would be nice to know what to expect from my PCM when weather goes weird...
Old Dec 12, 2008 | 05:55 PM
j tate's Avatar
j tate
i know my 92 has a baro sensor
Old Dec 12, 2008 | 08:36 PM
Dave Sponaugle
I think you will find the baro sensor only affects the tranny changing altitude.
My guess is higher shift RPM at high altitude, lower shift RPM at lower altitude.
Old Dec 12, 2008 | 11:31 PM
ford trans tech
actually it is there to cause the transmission to shift a little earlier at higher altitude when looking at the throttle demand versus road speed
the engien has power loss at altitude and throttle demand is higher and can cause a scenario where the engine is at high rpm with no upshift so to speak plus it would have a harsh upshift
Old Jul 11, 2010 | 01:38 AM
chicagodragon's Avatar
chicagodragon
this is for low vacuum? i just got an idi as few hours ago and was wondering. there is a thread in the powerstroke section.
Old Jul 11, 2010 | 02:19 AM
chicagodragon
can anybody tell me what this sensor is? it was loose nd the wires look very bad.
