right turns in 4x4 binding and jerking - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Reload this Page >
Old 12-07-2008, 06:27 AM
jobofly
jobofly is offline
jobofly is starting off with a positive reputation.
Het Guys,
why does my truck do this? its only when i make a hard right turn. it kinda clicks and jerks. has anyone else had this problem?
Old 12-07-2008, 06:36 AM
bowdog
bowdog is offline
bowdog is starting off with a positive reputation.
Its normal
Old 12-07-2008, 06:37 AM
torkum's Avatar
torkum
torkum is offline
torkum is gaining momentum as a positive member of FTE.
Are you on pavement? I would check the cv joints.
Old 12-07-2008, 06:39 AM
jobofly
jobofly is offline
no i was off road, its normal?? that sucks, there has to be a way to fix that.
Old 12-07-2008, 06:56 AM
Bobby82490's Avatar
Bobby82490
Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Definetly look at the cv axles, its possible that the joints are worn out.
Old 12-07-2008, 08:25 AM
jobofly
jobofly is offline
what do i look for on the cv axles? im not sure how they are suppose to look
Old 12-07-2008, 09:01 AM
bowdog
bowdog is offline
Look for slop and play
Old 12-07-2008, 09:57 AM
torkum's Avatar
torkum
torkum is offline
Torn boots and no grease is a problem too.
Old 12-07-2008, 10:07 AM
galaxie641
galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Was it dry ground?
Old 12-07-2008, 10:51 AM
jobofly
jobofly is offline
kind of, it was a dirt road that was moist
Old 12-07-2008, 01:50 PM
96f150's Avatar
96f150
96f150 is offline
96f150 is starting off with a positive reputation.
I would have to say it's normal.Any type of "Hard" turn while in 4 wheel drive, puts a pretty good angle on the cv joints or any type of u joint.
Rich
Old 12-07-2008, 02:04 PM
rockstate45
rockstate45 is offline
rockstate45 is starting off with a positive reputation.
If there's no slippage, you will get some binding.
I agree with the rest about the CVs and stuff. Never hurts to look, especially if you have 87K miles on your truck and you're in 4wd often.
-rockstate
JstoneF150
2004 - 2008 F150
02-19-2015 08:57 AM
tkisling
20
10-12-2014 10:36 PM
Joco4x4
2004 - 2008 F150
02-27-2013 08:49 PM
ch435
06-11-2011 05:32 PM
dav3455
1997-2006 Expedition & Navigator
06-03-2011 09:48 AM
Quick Reply: right turns in 4x4 binding and jerking
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
