302 Swap 79 4wd
Old 03-17-2013, 12:52 PM
Brent Spoores's Avatar
Brent Spoores
Brent Spoores is offline
302 Swap 79 4wd
Hey guys im currently building a 306 to put in my 79 F150 4wd. Problem is does anyone know what oil pan i can use that will work with my application without hitting.
Old 03-18-2013, 05:38 PM
Brent Spoores
Bump
Old 03-18-2013, 06:27 PM
redroad's Avatar
redroad
redroad is offline
Your post says 306 .. Are you looking for a 302 rear sump oil pan
Old 03-18-2013, 06:40 PM
jim collins's Avatar
jim collins
jim collins is offline
I pulled a 302 out of a 81 van once and it had a rear sump or close to rear . Not a front sump because i had to change it to a front sump to use in a falcon. I don't know anything about a 306 , new to me never heard of one.
Old 03-18-2013, 07:43 PM
J ballan's Avatar
J ballan
J ballan is offline
I think the one on my 94 mustang had a rear sump pan? What transmission do you plan on running?
Old 03-19-2013, 08:18 PM
Drac's Avatar
Drac
Drac is offline
Save the old ones
Yep a van pan. But the dip stick is a bit intrusive. Modifi-able
Old 04-16-2013, 06:46 PM
Brent Spoores
Thanks for the replies a 306 is a 302 bored .030 over. Its actually a 308 because i had the shop do .040. Anyways, a van pan will fit? If so ill be on the lookout.
Old 04-16-2013, 08:40 PM
Black79's Avatar
Black79
Black79 is offline
I've got a 302 in my 79 4x4. I'm running one of those "dual sump" fox body mustang pans. It clears everything just fine.
Its like this one
Black Oil Pan Ford 302 83-93 Mustang Dual Sump
Old 04-16-2013, 11:58 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
I have the same as Black79, works great with plenty of clearance. My truck is a '77 4x4
Old 04-17-2013, 07:13 AM
jim collins
With a van pan you only have one drain plug and it all drains. The 83 mustang i had back then had two drain plugs and you do need to remove both to get all oil out .It's okay but just another plug and seal to maintain when you service it.
Old 04-17-2013, 09:47 AM
Drac's Avatar
Drac
Drac is offline
Save the old ones
Very True about the fox body pan. They do work.
On my current project, I used a Moroso 351w pan for a fox body. works great, but yeah there are 2 drain plugs.
If you have a 4" suspension lift a front sump pan can work. but it will crash with the axle if it is not lifted.
hasteranger
04-29-2016 03:28 PM
79f150TX
04-30-2005 10:55 PM
Cliffdog
03-02-2005 09:32 AM
79 posi
02-01-2005 07:45 AM
oldhalftons
12-03-2003 06:40 PM
Quick Reply: 302 Swap 79 4wd
