Dual oil filters
I had a nice lengthy post all typed out and was adding pictures right when my computer decided to crash. This post might be a little shorter...
While I didn't install these parts on a modular truck, the part numbers and info all carries over. I'm running a remote mount oil filter on one of my cars. I used a Permacool spin-on adapter and Permacool filter mount, both of which I bought through Summit. The Summit part number for the spin-on adapter for Ford modular engines is PRM-118, and the part number for a dual filter mount (accepts two FL1A filters) is PRM-1221. On a relatively stock mod motor, -8AN lines are sufficient. I had to step up to -10AN lines in my case, as the -8AN lines were beginning to restrict flow. Here are a few pictures:
Spin-on adapter on the engine (taped up in this picture to keep any dust from getting into the engine):
Single filter mount with -10AN lines:
I have no complaints whatsoever with the Permacool pieces. I've been very happy with the whole setup.
In case you were wondering what this is in:
-Rod
-Rod
Whitemax
I have question for that oil filter.
Can I add another filter on it? Is 2 filters too much for this engine's oil pump?
I have 1 owner with 2001 F250 but can't believe he didn't change oil 20,000 miles overdue Now he call me say that engine tick loud. I immedity went there. It was low on oil but I have told him keep check but never did.
I do think 2 filters will help clean oil more better but not sure if it good idea?
Nice set-up white max
This is off topic, but is there just the one lower bolt in the valve covers of the DOHC? My sister in-law has a 93 Mark VIII and it needs a set of gaskets after only 220,000 miles. The seals are leaking into the plug pockets. It the onlt blot is the front lower, then I can probably change them. That car is too tight to work on anything. I understand whey you moved the oil filter, major PITA even on a 2V Cougar. (Niece has one of those). I couldn't tell by the picture if there was a bolt in the rear bottom corner or not.
Marsupial
1999 to 2016 Super Duty
13
05-02-2017 09:41 AM
fabsroman
03-06-2016 09:08 PM
02sd
01-02-2015 06:23 PM
