OUTSIDE winter storage prep for
Cry alot. Make sure all your fluids are topped up. Insure a good mixture of antifreeze is in the cooling system and completely drain you windshield washer resivoir, it gets gunky after while. A good cover would help keep the leaves from leaving stains on the paint. Harbor Freight sells a portable storage garage for not too much money. If I could have one(zoning) I think that's what I'd do.
Kevin----you know what to do.
You should have ALL your trucks inside with that big building you built.
I have room for mine--but my big 56 is too high with the 18' vanbox.
I have a california-car cover(best ever) and it sits on the concrete pad I have for it.
I hope to have all my trucks covered in a week since I just got back. I do all the antifreeze and car-covers at 1 time and it usually works good.
That big yellow56 needs cleaned and waxed and all new antifreeze and oil and a california truck cover and set it on some concrete so it won't sink in the dirt--and you will be fine--also put a humidity/moisture box in the cab(lowes) and check it for squirrels and mice every month while you start it up.----good maintenance---and try to keep everything inside if possible.........Bill
Bigwin
I hate the smell of mothballs and reminds me of my grandmas attic--haha!!
I would rather have mice.....haha
Hey---ibuzzard wants an oil pan from my yblock. Is there something special about it? I hate to tell him no--but so far do not want to separate it till I find a replacement engine.
Bill
Bill
Back in the early days of owning my '69 I had to find winter storage for it(had to give garage back to mom). It spent a few winters out in the corner of the backyard.
Cleaned it up, backed it into position over top of very large piece of plastic(used to get 30x40ft sheets). Jack it up and put it up on ciderblocks(let tires hang) and cover with cloth truck cover. Take plastic and pull it up tight over top of truck and take another sheet and drop over top and tuck under tires. LOTS of rope and bungee cords kept it all tight. A large piece of plywood over bed kept the snow from collapsing that area.
Did this for like 3 winters? Finally had enough money to buy storage garage for winter months after that. Couple years later I bought my own house and it wasn't a problem then.
One winter I left it outside and forgot to unhook the battery!! Come spring it fired up with no problems! Never really change antifreeze or used stuff like Stabil either.
bigwin56f100
22
10-02-2012 10:55 AM
bigwin56f100
05-19-2009 04:46 PM
bigwin56f100
39
04-23-2009 07:46 PM
