Fuel Tank Return?????
Old Dec 1, 2008 | 12:38 PM
snowman84's Avatar
snowman84
Cool Fuel Tank Return?????
Hey guys i need help! My '94 7.3L is going through fuel like crazy on the front tank. But not the rear tank?? So last night i filled up both tanks and this morning on the way to work (which is only 24km's) i burned up 1/8 of a tank. When i got to work i decided to add a bottle of Howes additive. I opened up the rear tank and fuel started to pour out on the ground????? Is the tank selector switch not working properly or what??? Any help would be greatly appreciated!! Thanks!
Old Dec 1, 2008 | 01:20 PM
91f2504x4's Avatar
91f2504x4
Sounds like your selector valve is bad and returning all the fuel to the rear tank. I think I would just run it off the rear tank until you got the problem fixed.
Old Dec 1, 2008 | 03:15 PM
snowman84's Avatar
snowman84
ok thanks. just wanted to c what what some other people thought. thanks alot.
Old Dec 1, 2008 | 09:12 PM
PLC7.3's Avatar
PLC7.3
Sounds like the FSV is not closing correctly on switch over..... when you switch tanks does the FSV make a ZZIIPP noise... Does the fuel guage switch tanks, as it is the last thing to complete. Gas or diesel FSVs from 88-98 will work if your a wrecker diver.
Old Dec 2, 2008 | 10:30 AM
snowman84's Avatar
snowman84
I personally dont like to use parts from a scrap yard on my fuel system, but if i have to i will. And yes the gauge does switch when i switch the tanks.
