Nebraska Chapter Join Chapter, Leader: 97nukeford
POR-15/ other rust encapsulators
Old 12-04-2008, 02:05 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
Have any of you guys used POR-15, or any other products, like Eastwoods, on a frame or suspension peice? I know George (gquinn8516) I think has used POR-15, but I'm just trying to get a comparison of the othe products, for use on my 67.
Old 12-04-2008, 07:33 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
I used a paint called Chassis Saver. I really liked the durability of it and it is made to paint over rust right out of the can. POR-15 takes many steps to get it to work properly (from what I read) and it's way more expensive. But, if following all the steps correctly for POR-15, I believe its a pretty good product.
The downfall of Chassis Saver is that it's UV sensitive, so anything exposed to sunlight will change the Gloss Black to a charcoal or even a grey. The silver color doesn't change much. If I had to do over, I probably would have used Rust Bullet. It's supposed to be as durable and paint over rust application but UV resistant.
Old 12-05-2008, 09:41 AM
67nukeford's Avatar
67nukeford
I've read that POR-15 has the same issues with UV sensitivity Buck. I did read an article about the stuff Eastwood sells, that was out of a restoration magazine, that they have posted on their website, I'm just waiting to find some more info.
Did you spray, or brush yours on Buck?
Old 12-05-2008, 04:46 PM
bucks77ford
I did spray the frame and axles, but my inner fenders and other parts I brushed it on. You really can't even tell I used a brush either. It evens out pretty well. I only sprayed the frame because at the time, I had access to my brothers mechanic shop and his tools. If I didn't, I probably would have brushed it on.
