NY's December BS and chat... ALL WELCOMED
#61
Hey Pat just looked at that video, isn't there a song about that? "In the doghouse now". Reminds me of the time when I went to pitch horseshoes on our anniversary...
#62
Ut Ohhhh!! what did the missus have to say to that ??..... unless she was there pitching them with you.
#64
Howdy Michelle.... how are things out west today???
Here it is freezing cold!!!!!!!! Temps in the mid 20's and windchills in the teens.
#66
Hey everyone,
I had a little mishap with the truck today. My oil pressure sensor found its way out of the back of the block!!! IT sprayed oil everywhere. Hope I didn't lose too much to dause permenant damage. MAybe someday I will get that thing squared away. I guess it was better to happen in town then on the freeway. Anyway, hey michelle that dessert looks delicious!!! Later guys.
#68
Jonathan, sorry to hear about the oil pressure sender and as you mentioned, hopefully it did not cause any permanent damage. Good luck with it.
I know first hand what kind of mess the oil sender can make. I had a 84 Monte Carlo that I ended up replacing the 229 V6 with a slightly built small block 400 after the 6 spun a couple of rod and cam bearings.
Anyways, I had a triple guage under the dash to measure water temp, voltage and it had a mechanical oil gauge. For some reason I did not get the tubing fully seated into the sender and needless to say that with a hi perf. oil pump, she popped right off and sprayed oil aaaaallllllllll over the place. What a mess that was to clean up.
#69
Anyone want to try to keep up with the Jones'.......
210,000 Christmas lights. Computer animated and synchronized to music in Pittsburgh Pa - iReport.com
Make sure that your volume is turned up.
#75
Too busy playing around in the cold to post. It took about 45 min for fingers to thaw out so I could push the keys.
