390 won't start when warmed up
So I bought a 68 f100 that has been sitting for quite some time, I had to have the carb rebuilt, replace battery and the tires cuz they had flat spots from sitting so long. I drove the car a few months and now when I stop to fill up on gas I can not get it started again, unless I park on a hill and let her roll and pop the clutch. The engine turns over fine and it feels like it would start once but if it does not start that one time I need to find something else to do for a while to let the engine cool down before it will start again(like I flooded the engine?). Also it runs real rough at idle unless I plug the vacuum line going to the carb. Any ideas on what makes the truck unable to start when warmed up unless I doing a rolling start?
Just giving obvious things to check. Not debating over a car I can't see. Bump starting will sometimes start an engine if the starter is not turning it over fast enough. Another item too check is the starter. If the exhaust is to close to it and it over heats it will not turn over till it cools down. Been there done that one.
Received 3,099 Likes
on
02GrayPowerStroke
1997 - 2003 F150
08-19-2019 01:16 PM
woodsmoke
13
09-19-2017 07:45 PM
dragon250
06-07-2011 11:30 PM
Fordenthusiasts
03-01-2008 01:18 PM
explorerdad
09-05-2001 06:39 PM
