clutch fork proper install?
Old Nov 30, 2008 | 01:09 PM
White97's Avatar
White97
1965 f100, 352, 3 speed manual.
Is the clutch fork supposed to pivot off the trunnion nubs, or does it just rest on them and only the anti-rattle spring goes in the holes on the fork? The trunnion is inside the bellhousing and looks to be in good shape as does the fork.
I put the fork in a vice and closed the distance between the upper and lower wall a bit and now the spring stays in nice, but the fork still does not rest and pivot on the trunnion numbs. When I pulled this all apart everything fell out, so I did not see how it was all in there originally.
I don't really have much history on this truck, but there are clues that there are many donor pieces on it, so this may just be an issue of the wrong parts.
Pictures of trunnion and fork
https://www.ford-trucks.com/user_gal...?albumid=36687
