I have a 2000 F250 - 7.3 manual tranny. Today I was driving home to Ft. Lauderdale from my hunting camp in Georgia. When we hit Jacksonville, white smoke started coming out of the exhaust. It got thicker as we kept driving. Around West Palm Beach, while my son was driving - the engine started to shutter a bit while he mashed down the accelerator to the floor. Finally, he pulled over and it stalled out. It was not running too hot and the oil level was fine. I didnt check the coolant level. I recently replaced the HPOP and the regulator. Any thoughts.....?????
Welcome to FTE. My thought would have been a blown seal in the turbo, but since he kept driving it until it stalled, that would have meant little to no oil showing on the dipstick.
How far was the truck driven after it started smoking until it finally died?
I would have thought turbo seal blown out as well and a low oil level causing the stalling, but the OP says the oil level was fine, so that almost rules out that idea. I would be checking the coolant level.
Thanks for the thoughts. As I said - I did not check the coolant level. Come to think of it, when I pulled over to check the smoke, it smelled like hot radiator water/coolant. I am guessing its coolant in the fuel.
Typically, and there's always the rare exception, because the fuel pressure is higher than the coolant pressure a cracked injector cup will allow fuel to get in the coolant rather than coolant in the cylinder. Had a cracked cup years ago. Had no smoke but fuel in coolant. You could smell fuel in the degas bottle.
Okay guys - here is the answer - the turbo is shot and the engine was injecting oil into the exhause which when burned caused the heavy white smoke to come out of the exhaust. New turbo - about $1,100.00.
Thanks for following up and telling us what the problem turned out to be. Strange the oil level was fine after burning that much oil for so long. I would have thought the oil would have been close to empty. That's something to keep in mind the next time we read something like this.
