6637/ now a fuel leak!
Old 11-27-2008, 07:11 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
kupiec20 is starting off with a positive reputation.
i put in the 6637 filter w/ a 45* aluinum 4 in pipe yesterday now there is fuel leaking down the back side of the oilpan/i dont know much about these trucks so if you have any ideas what i did or might have hit something ect..
Old 11-27-2008, 07:45 PM
jeep1947
jeep1947 is offline
jeep1947 is starting off with a positive reputation.
Possibly fuel pump or loose clamp on one of the fuel hoses. Take a flashlight and a small mirror and check weep hole on bottom of fuel pump. When they leak it fills the valley with fuel and it runs down the back of engine and runs down bellhousing.
Old 11-27-2008, 08:20 PM
kawa's Avatar
kawa
kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
You will need to really clean and mop the valley with paper towels. Get it as dry as possible. Then with a good swivel mirror and a bright flashlight start the engine and start looking for the leak. The weep hole on the back, bottom if the fuel pump is always a good start.
Leaking fluids that get into the valley travel towards the rear and exit through a drain hole on the passenger side of the valley.
When you locate the leak come on back and we'll tell ya how to correct it.
Happy hunting.
Rog
Old 11-28-2008, 12:22 AM
Todd525's Avatar
Todd525
Todd525 is offline
Todd525 is starting off with a positive reputation.
FYI, after you get it dry, and I mean DRY, you can throw in a little baby powder in the valley to see where it starts from. You prolly lost the fuel pump. It runs about 75 bucks or so, and take about an hour to put it in. DO NOT TAKE IT TO A SHOPP TO HAVE THIS DONE. They charge you to take turbo off etc... and turbo stays on the truck. We will walk you thru it step by step, no worries. Plenty of guys like me and others have changed out more than a dozen of these, some more than 50.
Old 11-28-2008, 06:19 AM
Sangetsu03
Sangetsu03 is offline
Sangetsu03 is starting off with a positive reputation.
Ditto the above,
Old 11-28-2008, 10:36 AM
Talyn's Avatar
Talyn
Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
The filter doesn't go on the fuel system, it goes on the air intake.
=D
A/Ox4
05-15-2011 07:48 PM
crazer42
17
01-30-2010 05:53 PM
mechelement
15
09-05-2009 08:18 AM
JRStraight
06-04-2008 08:38 PM
mcallister
04-10-2008 09:20 AM
Quick Reply: 6637/ now a fuel leak!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
