Dana 60 Bolt pattern
Old Nov 27, 2008 | 01:43 AM
Bender99's Avatar
Bender99
Can i get a Dana 60 to a 5 bolt pattern? Probly dumb question! reason i ask is cause i bought a 79 doner truck to swap solid 44 front axle with my 91 short box. Both axles are 8 bolt and i want them both 5 on 51/2 so i can still run my mickey thompson rims. My plan is to switch the 460, c6 trans and both axles and 6 inch lift from the 79 to my 91.
Old Nov 27, 2008 | 10:08 PM
hotroddually's Avatar
hotroddually
i would just buy proper 8 lug rims and 16 " tires,and sell the 5 bolt half ton rims and tires to offset the cost.it would be way simpler .
Old Nov 27, 2008 | 10:42 PM
75F350's Avatar
75F350
You can, and there are kits available, but they are spendy. You will spend more money converting these to 5 lug and using half ton brakes than it would cost to buy new wheels.
Here is a chevy / dodge bracket (note 6 holes for the spindle) and it is clearly a 5 on 5.5" pattern.
[IMG][/IMG]
This kit can run around 500 bucks.
A better idea might be to get 8 lug 15" wheels so you can keep you tires.
With the correct backspacing you can clear big brakes with 15" wheels. I run 15 inch 8 lug wheels on several of my one ton rides.
Old Nov 28, 2008 | 06:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
IF you can find one, Ford offered a 5 lug 5.50" bolt circled Dana 60 as an option on 1961/67 F100's with or w/o Limited Slip.
Old Nov 29, 2008 | 12:32 PM
Bender99's Avatar
Bender99
Thanks for the input guys. Its not that big of a deal to sell my rims and buy new ones but I read that 5 bolt danna 44 is stronger cause you can fit larger u joints. So i was thinkin about that also
djbonsu
Jan 12, 2021 01:59 PM
650
Apr 5, 2016 03:08 PM
mmperfdiesel
Mar 31, 2016 07:58 PM
Bubba Jones
1978 - 1996 Big Bronco
18
Feb 14, 2016 11:04 PM
AKTraveler
May 9, 2003 07:54 AM
